Intermittent Noise Above 60 MPH
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jagergirll, Aug 6, 2018.
  1. Aug 6, 2018 at 3:24 PM
    jagergirll
    jagergirll [OP] Well-Known Member
    Sam
    Midwest
    4x4 RC
    OME Suspension ARB Bumper Rock Sliders BFG KO3's Camper Shell
    https://youtu.be/TZmTj9q1ffU
    Problem found. Bad yoke ordering a custom greasable driveshaft. The yoke did not have a way to be greased on this RC drive shaft.
    Hey TW, it’s hard to hear this intermittent noise in the video but best I could get. Put a OME suspension on and after the alignment my truck seems to randomly make noise in 4th, 5th or with clutch pressed in when I’m going over 60mph. It does not do this if there is tension such as accelerator pressed only when going down hill or foot is off the gas.
    Wheel bearings were changed a couple months ago. The noise also happens with and without the dif drop kit so I took it off.
    Thanks for ideas.
  2. Aug 10, 2018 at 4:46 AM
    jagergirll
    Sam
    Midwest
    4x4 RC
  3. Aug 10, 2018 at 5:50 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    remove front drive shaft and still makes the noise?
  4. Aug 10, 2018 at 6:00 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Are you getting any kind of good vibrations?
    If so throw it into 4wd and see if they go away.
    Inkedgenius85 likes this.
  5. Aug 10, 2018 at 5:09 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    No vibration at all. I don’t drive over 60 mph in 4 H so I do not know if it would make that noise.
  6. Aug 10, 2018 at 5:11 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    Have not done that but maybe I’ll give it a go but I didn’t think the front drive shaft would turn unless it’s in 4WD
  7. Sep 15, 2018 at 5:23 AM
    jagergirll
    Sam
    Midwest
    4x4 RC
    Bump any other ideas?
  8. Sep 15, 2018 at 10:32 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Did you use the carrier bearing drop from ome? I had a hum at or around 50mph but would instantly go away when lifted off throttle. Removed it and everything is fine now
  9. Sep 15, 2018 at 2:52 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    RC didn’t require that. The noise goes away under tension. When I let off the gas peddle. When I open the back slider the noise is really bad. Dealership said the drive shaft and u joints were fine?
  10. Sep 15, 2018 at 3:09 PM
    sgage
    sgage Well-Known Member
    2007 Red Tacoma SR5
    I had what I think is a very similar symptom - for me it occurred at 45-50 mph. It only happened when letting off the gas - would go away when I pressed the pedal and accelerated even slightly.
    I had my frame replaced in July, also leaf springs. I actually had the lift in the rear dropped - it was really jacked up when I bought the truck. When I got my truck back, the noise was gone. The clutch seemed to operate more smoothly, too, when taking off in first from a stop.
    In my relative ignorance of these matters, I figure it had something to do with the driveline angle. But that's just a SWAG. Did you change the lift a lot? I believe some people who have had a similar issue have installed some sort of shim to fix it. Again, I am not really all that knowledgable about this - just relaying what I've read in the forum here...
  11. Sep 15, 2018 at 3:47 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Did you have your pinion angle shimmed? I know having misaligned ujoints will cause a vid but they can also put stress on the pinion bearing causing it to hum.
  12. Sep 15, 2018 at 5:32 PM
    dreadedyota
    dreadedyota Well-Known Member
    Ernest
    Ontario Canada
    2008 Black Tacoma TRD.SR5.Sport
    Camburg UCA,Cowl Induction, ECGS, Exhaust Reroute.
    I have an intermittent hum at higher gears when decelerating and not turing accel due to center support bearing or hanger bearing, worth checking out
  13. Sep 15, 2018 at 6:20 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    These are good ideas hopefully I can figure it out soon. I think I’ll have another shop look at the angles.
  14. Sep 16, 2018 at 10:11 AM
    jagergirll
    Sam
    Midwest
    4x4 RC
    Updated sound. According to the phone AO I used my driveline angle is 6 degrees. I’m gonna throw a couple feed bags on the front and measure it with the weight of a winch. Then look at putting in shims.
  15. Sep 16, 2018 at 1:24 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Have you checked the heat shields around the exhaust and cats?
  16. Sep 16, 2018 at 1:47 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    Yes I checked them. One was rusted pretty bad so I put a new clamp on it. That sounds gone but it’s not the sound that’s going on. Ow!
  17. Sep 16, 2018 at 3:49 PM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    put a gopro under your truck. reproduce the noise. move the camera, reproduce the noise... rinse repeat until you found the source. I did this trying to find where a rock was rattling around. it was actually a stuck branch that was tapping the floor pan by the exhaust shield.
  18. Dec 20, 2018 at 8:19 PM
    jagergirll
    Sam
    Midwest
    4x4 RC
    Bump.
    3 mechanics say it’s nothing. Me and one mechanic say it’s the drive shaft angle causing noise at the rear dif from my OME lift. Question is what shims to use. I have 887 up front with an ARB bumper but no winch yet. That phone ap has my drive shaft angle at 6 percent instead of 4 prior to lift sure those aren’t the real numbers but same ap and phone. So should I do the 2 degree shims by doing the shims will I cause more damage to the gears vs just leaving it as is?
  19. Dec 20, 2018 at 8:29 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Leafs. 110% sure, leafs are rubbing, pads wore out.
  20. Dec 20, 2018 at 8:31 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
