Intermittent sound between shifts
Discussion in 'Technical Chat' started by TaCoLoCo®, Jul 18, 2009.
  1. Jul 18, 2009 at 11:10 PM
    TaCoLoCo®
    TaCoLoCo® [OP] conquistador
    Dave
    Euless TX
    2006 Tacoma DC TRD Prerunner
    The sound is very intermittent, It usually happens when shifting from 2nd to 3rd gear. It sounds like someone is tapping the floorboard with a hammer after the shift. The vehicle in question is a 2006 Toyota Taco DC Pre Runner 2wd automatic trans.
  2. Jul 19, 2009 at 7:21 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    How rapid is this tapping sound?
    Does it definitely sound metallic (metal-on-metal)?
  3. Jul 19, 2009 at 9:44 AM
    TaCoLoCo®
    Dave
    Euless TX
    It sounds like a thud and it only thuds once after the shift from 3-4 or 2-3 but it dosent happen every time.
  4. Jul 19, 2009 at 9:55 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Does it usually happen only when accelerating pretty hard? If it thuds only once, it might be axle wrap or a driveline connection issue.
  5. Jul 19, 2009 at 10:12 AM
    TaCoLoCo®
    Dave
    Euless TX
    yes it occurs when under a medium to aggressive acceleration.
  6. Jul 19, 2009 at 10:13 AM
    TaCoLoCo®
    Dave
    Euless TX
    whats axle wrap?
  7. Jul 19, 2009 at 10:45 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    'Axle wrap' is when your rear leaf springs deform or twist under load (e.g., causing them to bend into an 'S' shape rather than their usual 'U' shape).
    Here's an illustration from DesertRides:
    This can cause damaging stresses to the rear and throw things out of alignment (e.g., the pinion angle).
  8. Jul 19, 2009 at 12:01 PM
    TaCoLoCo®
    Dave
    Euless TX
    is there anything that can be done to prevent it? AAL?
