Internal Lighting in switches
Discussion in 'Lighting' started by RSTEVEN, May 25, 2012.
  1. May 25, 2012 at 1:15 AM
    RSTEVEN
    RSTEVEN [OP] New Member
    TRIAD security system
    I have a 1999 Tacoma 4x4 TRD that I just purchased last month.
    Notice the ECT and Diff Lock switches are back lighted.
    My Hazard light switch does not illuminate at all.
    Looking in my Hayes Manual electrical shows a light in the switch.
    My question is what is the replacement bulb and any ideas on changing it.
    While I was replacing the back lighting on the temperature control panel notice that the AC switch looked like it had a small round "cap" that might be a lamp?
    Any ideas ??
  2. May 25, 2012 at 1:30 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    While I personally don't know the answer to your question, I've relayed it to someone who might. He should be on tomorrow sometime.
  3. May 25, 2012 at 7:57 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    i think the 1st gens buttons are the same as the 2nd gens....they have a really small bulb in each button for lights...:notsure:
  4. Apr 27, 2013 at 8:24 PM
    RSTEVEN
    Pulled the dash apart and got to the Hazard Switch ... was able to remove the internal backlighting light bulb .. was in a gray round base.
    The bulb is a miniture grain of wheat bulb ... Toyota Listed it as 14v .91 watts
    was able to find a #2182 lamp ( wire terminal base T1 3/4 ) that worked.
    The little gray lamp holder has two holes in the bottom in which the lamp wires go through, then up and over the base. Just take your time when you remove the old lamp and see how the wire leads are routed.
    Up and working now .....
