Introducing 2nd and 3rd gen antenna cover replacements
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Anderson, Aug 24, 2019.
  1. Sep 8, 2019 at 11:07 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Shark Fin Antenna Replacement - Starting from the passenger side, here's how I recall doing it:
    (Again, referencing this post, please proceed at your own risk! I had some minor dents in the plastic... I had to drill a hole for the small stubby shark fin pic # 7 & 8, my FM radio/XM replacement antenna details are here and here).
    Edit: there is another post here where he drops the headliner...
    • Pull the rubber door trim at the liner and side panels,
    • remove the headrest and fold the back seat down,
    • unbolt the panel behind the seat so that it is loose,
    • using your fingers, a finish tool, or small flathead screwdriver, pry the two side panels loose by popping the tabs from the pillar (pic #1),
    • use a razor blade or finish tool to pop the SRS cover (pic #2),
    • unbolt the SRS #10 bolt (pic #2),
    • pop the covers off the oh-shit-handle with a small flathead screwdriver (pic #3),
    • pry out the tab that holds the clip and remove handle (pic #3),
    • repeat for the coat hooks, remove the covers with a small flathead and release the tab for both clothes hooks (pic #4),
    • observe how the liner is tucked up against the back window,
    • starting at the door, gently pull the back side of the headliner down while trying not to dent the headliner or crease the headliner (there are no hidden screws or tabs to pop out - it just comes down, stop pulling when it gets near the dome light, pic #6),
    • pop the tab on the side pillar at the shark fin electrical connector (pic #5),
    • release electrical connector (pic #5),
    • open back window,
    • unscrew shark fin bolt with an open-end wrench (pic #6 & 7),
    • repeat in opposite direction for re-install.
    Hope this helps! Please pm me if you have specific questions as I don't always check threads. Good luck!
    3
    4
    5
    6
    7
    8
    Papa_Smurfin, Slashaar and Rainoffire like this.
  2. Sep 8, 2019 at 11:15 AM
    RyanDCLB
    4/19 DCLBOR
    Oh shit handles and coats hooks both have caps and clips for the 16+. The newer model coats hooks don't twist out... I tried ;)
    tcjacado[QUOTED] likes this.
  3. Sep 8, 2019 at 11:24 AM
    oni06
    oni06 Well-Known Member
    If you start selling these I would love to purchase one.
    Following.
    Anderson[OP] likes this.
  4. Sep 8, 2019 at 11:31 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    In for price....
  5. Sep 12, 2019 at 7:21 AM
    Anderson
    Anderson [OP] Dudemanbro
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Small update:
    We have 3 different samples on their way back to us at the moment. We are still trying our hardest to get to a reasonable price point. We may have to ditch some smal design features to get to where we want to be price point wise. The brass inserts may have to go. We will see.
    Also, we are working on a 3rd gen soon.
    cjfly, MapJunkie and notlefty like this.
  6. Sep 12, 2019 at 1:38 PM
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
    As a potential buyer, I would rather pay a few extra dollars for quality than to have to take this off every year or so to check for rust. This will be exposed to the outdoors 24/7 and even though there is a seal around this, that’s just another part to worry about. Just my 2 cents.
    oni06, rob1208 and notlefty like this.
  7. Sep 12, 2019 at 1:55 PM
    Anderson
    Anderson
    Benicia, CA
    ProBro
    Stuff
    The brass inserts will be sealed from any potential weather issues by the factory rubber weatherstripping. However, the factory sharkfin screws terminate directly into plastic. We were trying to elevate the design and build positive engineering features into the product. We may have to remove the brass inserts due to cost. That would just put us back to exact factory likeness in the respects of the functionality of the fastening screws.
    notlefty likes this.
  8. Sep 16, 2019 at 11:25 AM
    Anderson
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Update:
    Brass inserts have been nixed from Design.
    Found supplier pending sample inspection
    Price point would be $45 plus shipping at a minimum of 50 ordered.
    Turn around time would be approximately 4-5 weeks.
    Order needs to be placed at a minimum of 50 items.
    Hopefully there is enough interest to get this done.
  9. Sep 16, 2019 at 11:26 AM
    Anderson
    Anderson
    Benicia, CA
    ProBro
    Stuff
    3rd gen Bullet Cover design is coming forthwith.
  10. Sep 16, 2019 at 6:30 PM
    MapJunkie
    MapJunkie Well-Known Member
    Washington
    2015 Tacoma OffRoad w/ Drifter
    Count me in for your first order!
    Anderson[QUOTED][OP] likes this.
  11. Sep 16, 2019 at 8:44 PM
    oni06
    Me to
  12. Sep 17, 2019 at 6:18 PM
    Denk
    Denk Well-Known Member
    PNW
    '13 Spruce TRD Sport DCSB
    In yo
  13. Sep 17, 2019 at 7:31 PM
    Anderson
    Anderson
    Benicia, CA
    ProBro
    Stuff
    Right, I see that we have some verified interest. I’ll edit the first post to reflect all those that are interested.
    I figure I should compile a post a put it in the group buy section to see if we can get more traction to reach that 50 item threshold. Maybe I can get time to figure all that out tomorrow morning. Fingers crossed.
    As an aside. I am a small business owner with a very full plate at the moment. This is a side project for me. I hope that my timeline hasn’t put people off this far. I’ve tried to be open and transparent with my information. You can always ask me questions and I’ll answer them to the best of my ability.
    rob1208 likes this.
  14. Sep 17, 2019 at 8:16 PM
    notlefty
    notlefty Probably Wrong
    Dixon
    2019 TRD Sport Access Cab M/T
    In for 3rd gen model ..
  15. Sep 17, 2019 at 8:18 PM
    #35
    Anderson
    Anderson
    Benicia, CA
    ProBro
    Stuff
    As soon as I can get a test subject for a couple of weeks...
  16. Sep 18, 2019 at 12:47 AM
    #36
    SK808
    SK808 Well-Known Member
    Ewa Beach, Hawaii
    2017 Tacoma TRD OR DCSB 4X4
    Magnuson Supercharger, Kings w/Resi front and rear, ICON UCA, Allpro STD leaf pack, C4 Fab Hybrid Front Bumper, RCI Rear Bumper, X20 winch, All Pro U-bolt Flip Kit w/ wheelers bump stop, Method 701, 17X8.5 w/0 offset, BFG KM3 285/70/17, All Pro Sliders, TRD CAI, Spec-U exhaust, Total Chaos bed stiffener, RCI Skid Plates (all skids), Wet Okole seat covers, Diamondback tonneau cover, Grillcraft MX Grille, Husky front floor mats, Weather Tech rear floor mats, bed mat, various Baja Design lights, mobtown tailgate reinforcement plate, and a bunch of other stuff.
    I’m in for a 3rd gen model as well.
  17. Oct 5, 2019 at 5:29 PM
    #37
    Bensonfabworks
    Bensonfabworks New Member
    2014 DCLB Tacoma TRD
    OME BP-51's, Dakar leaf springs, custom front bumper, 285/70/17
    @Anderson Did this ever happen? I am interested in purchasing one.
  18. Oct 5, 2019 at 5:58 PM
    #38
    Anderson
    Anderson
    Benicia, CA
    ProBro
    Stuff
    We are still waiting on the final sample.
    I had no idea something I thought was this simple, would be this drawn out and this complex...
    oni06 likes this.
  19. Oct 9, 2019 at 7:28 PM
    #39
    joeydurango
    joeydurango Nightfall Overland
    SW Colorado
    Heavily modified 2015 TRD w/Drifter
    Okay, I'm curious. Sub'd.
  20. Oct 9, 2019 at 8:43 PM
    #40
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    In when these become available!
