Inverter anytime (stock)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aw113sgte, Dec 3, 2012.
  1. Jul 16, 2013 at 8:40 PM
    #41
    CampGuy
    CampGuy Well-Known Member
    Dmitry
    California
    2013 4x4 TRD-Sport
    Good Job MAN! I looking for it long time THANKS!!
  2. Jul 21, 2013 at 1:48 PM
    #42
    CampGuy
    Dmitry
    California
    2013 4x4 TRD-Sport
    Very simple and nice..
    I make too.. ;)
    Xmas79, MolonLabeTaco and Singu1arity like this.
  3. Dec 4, 2013 at 12:15 PM
    #43
    S4RSSS
    S4RSSS Well-Known Member
    NorCal
    4x4
    thanks for the photos and step-by-step simple instructions. on an earlier reply, a violet/purple wire needed to be cut as well... is that still required? i don't see that step above.
    thanks
  4. Dec 5, 2013 at 7:42 AM
    #44
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    I believe the violet & violet/white wires shown in the first post provide the 400W anytime mod.
    400W mod
    http://www.toyotanation.com/forum/6...284662-110v-factory-inverter-always-400w.html
    So if you follow the directions in the OP you would have an anytime inverter that is always at the full 400W
    The directions me and CampGuy posted only give you the anytime ability. The inverter will still revert back to 100W when the car is in drive.
  5. Dec 5, 2013 at 9:16 AM
    #45
    S4RSSS
    NorCal
    4x4
    Thank you!! Makese sense. Cheers.
  6. Jan 11, 2014 at 1:27 PM
    #46
    Poolstick
    Poolstick Well-Known Member
    So I did this, and it works with the keys in the ignition, but is there a way to get it to go w/o the keys in? I would like to keep the 100/400 functionality for the time being.
    Edit: wire going tied into the green wires is run straight off the battery, power source is not ACC for that one.
  7. Jan 13, 2014 at 8:05 AM
    #47
    rhavin42
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    Did you get this working correctly?
  8. Jan 16, 2014 at 7:07 AM
    #48
    Poolstick
    No.. Still trying to figure it out. Have been out of town though so I haven't worked on it much.
  9. Jan 16, 2014 at 9:08 AM
    #49
    rhavin42
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    The two red wires you see in my pictures (one under the hood, the other tied into the two green wires on the back of the switch) run BOTH of those red wires to an always on +12v source. The wire under the hood activates the relay to supply power to the inverter. The wire behind the switch powers the switch, which in turns tells the inverter to turn on when the switch is depressed.)
    The inverter will only turn on when BOTH of the added wires have +12v, It sounds like you might have one of the wires to an always on +12v and the other to a switched input that comes on with the key in.
  10. Jan 25, 2014 at 4:57 PM
    #50
    Poolstick
    Thanks for the tips guys. Now it works with the power off, but it seems my 400W light never comes on anymore. I'm not sure it that means I'm not getting the 400W or if just the light won't come on.
    I've got a 6speed manual, and putting it in gear/neutral/clutch in doesn't seem to make any difference. Thoughts?
    Edit: Nevermind, I figured it out. 100W will work with engine off (regardless of trans status), 400W works with engine on and trans in neutral. Now maybe I'll do the anytime mod and see if I can get 400W with the engine off...
  11. May 7, 2014 at 1:33 PM
    #51
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
