ION wheels fitment help
Discussion in 'Wheels & Tires' started by whiteyota, Feb 22, 2011.
  1. Feb 22, 2011 at 3:29 PM
    whiteyota
    whiteyota [OP] Well-Known Member
    Zachary
    virginia,caroline
    tacoma 97 4cyl spraypainting
    KC high lighters,K&N CAI,smoked tail light,corner,and3rd brake lights, clear turn signels, blackchrome headlights, blistien 5100s and aal, 800w soney amp with 1 kicker comp.10 custom box. pioneer door speakers and cd player, spray painted grill,door handels,wheel trim,tool box.
    hi, so just to double check will ION 15x8 with 3.5 Backspacing work with a 1997 toyota tacoma single cab 4x4 running 32x11.50 and blistein 5100s and add a leaf. http://www.jcwhitney.com/style-174-black-wheels/p2024164.jcwx?skuId=886016&filterid=j1
    I think the B.S is good and with the 11.50s the tires will stick out a little but i dont want the tires to rub the upper and lower control arms so i just need some clarification on if they will rub anything with the 11.50s
    [​IMG] Thanks, Zack
  2. Feb 22, 2011 at 5:35 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    I dont think people have issues rubbing LCA but the backspace is more than enough, stock backspace is 4.5 so u'll stick out enough to clear UCA and probably frame rub:D
  3. Feb 22, 2011 at 5:48 PM
    whiteyota
    Zachary
    virginia,caroline
    i think i will need a 4.00 in B.S then
