iPhone and qi charging
Discussion in '3rd Gen. Tacomas (2016+)' started by Tampa Scott, Apr 22, 2016.
  1. Apr 22, 2016 at 3:26 AM
    Tampa Scott
    Tampa Scott [OP] Active Member
    2016 Tacoma TRD sport
    Anyone have any luck finding an adapter that lets you wirelessly charge your iPhone? I am sending back the Bezelel adapter I bought on Amazon. It does not charge through a case (heavy duty defender or cheap plastic one) nearly impossible to disconnect the charging insert while in a case, in fact it tore after about 5 days of use. And it would never fully charge and get knocked offline while in charging mode.
    Let me know if you've found something that works. Thanks.
    Brian007Taco likes this.
  2. Apr 22, 2016 at 4:49 AM
    harryk
    harryk Well-Known Member
    Maryland, near Chesapeake Bay
    2016 Tacoma V6, MT, 4WD, Blue
    Also interested..
  3. Apr 22, 2016 at 4:58 AM
    Muffdiver
    Muffdiver Growing old is mandatory, growing up is optional
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
  4. Apr 22, 2016 at 5:02 AM
    Tampa Scott
    That's the one I just sent back. Doesn't charge through a case, very difficult to plug in while in a case and tore within the first week.
  5. Apr 22, 2016 at 5:21 AM
    Muffdiver
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
  6. Apr 22, 2016 at 5:30 AM
    nfidel
    nfidel Well-Known Member
    jim
    2016 TRD Sport 4x4
    If you're willing to shed your old case- I bought this model and it works great. The only issue I have noticed is if the phone is too far to the right in the tray, it won't charge- it will just blip back and forth from charging to not charging. That only happened once. The case is thin which I prefer.
    http://www.amazon.com/Charging-Rece...&redirect=true&ref_=oh_aui_detailpage_o02_s00
  7. Apr 22, 2016 at 5:44 AM
    Muffdiver
    Ty
    Elkhart, In
    2012 TRD OR DC 4x4
    I'm not using a case. I've just attached it to the phone with clear packing tape.
  8. Apr 22, 2016 at 7:58 AM
    muchostacos
    muchostacos Member
    Houston, TX
    2016 White DCLB TRD Off road
  9. Apr 22, 2016 at 8:28 AM
    TyFX
    TyFX Well-Known Member
    2016 TRD Sport 4X4 Access Cab - Inferno
  10. Apr 22, 2016 at 10:58 AM
    Malibu7tss
    Malibu7tss Can' t think of anything to type here right now.
    Central pa.
    2016 trd sport dcsb 4x4 bbp 6spd manual
    Old man emu with 888's and headstrong off road progressive aal, trd pro wheel, Cooper Stt Pros 285/70r17
  11. Apr 22, 2016 at 11:01 AM
    TyFX
    I'm hoping the iPhone 7 has qi charging built in.
  12. Apr 26, 2016 at 9:14 PM
    TacoFJ
    TacoFJ Member
    Apple will probably develop their own wireless charging standard, knowing them...
    josowski, TyFX and justintackitt like this.
  13. Apr 26, 2016 at 10:00 PM
    justintackitt
    justintackitt Well-Known Member
    2016 Tacoma DCTRD4X4
    Yup!
  14. May 2, 2016 at 6:34 PM
    Tampa Scott
    After writing a lousy review on Amazon, the company sent me an email offering to send me the charging case free of charge in exchange for removing the negative review. I agreed and it showed up today. The case works great with the charging pad in the Tacoma. It also seems much better built and sturdier. Looks like I found a winner.
  15. May 2, 2016 at 6:43 PM
    Gus Gorilla
    Gus Gorilla Well-Known Member
    2016 White TRD OffRoad
    None...yet
    Link to the good case?
  16. May 3, 2016 at 3:01 AM
    Tampa Scott
  17. May 9, 2016 at 2:05 PM
    MagnumTaco
    MagnumTaco Well-Known Member
    Tony
    New Mexico
    Supercharger, Baja Suspension, TRD exhuast, Stealth pulley.
    Ok, I am having an issue with my wireless charger. I use the Spigen qi charging case for the iPhone 6s. Sometimes it works sometimes it just blinks green and orange. I am starting to think its the truck. When I put the phone down on its own wireless charger it has zero issues. Is there a trick to the truck charger?
  18. May 9, 2016 at 5:27 PM
    Tampa Scott
    I put it far to the right with the home button facing left right up to the front edge. It works for me.
  19. May 9, 2016 at 11:52 PM
    TRDoverland
    TRDoverland Well-Known Member
    Kevin
    Petaluma, Ca.
    2016 Tacoma TRD Off Road - MGM
    Has anyone found an iPhone6 Qi charging case that also allows you to charge your phone with an existing lightning charger when you're not in the truck?
    It would be nice if I could still quickly use my long charging cables without taking off the Qi charging case when I'm not in the Tacoma... And/or avoid buying Qi charging docks for work/home for the time being.
    damnfingers likes this.
  20. May 10, 2016 at 6:08 AM
    SqFt
    SqFt Well-Known Member
    2016 Tacoma TRD Sport
    Something like this? http://www.amazon.com/Touch-Charge-Removable-Lightning-Connector/dp/B00WMQRMRO
