Is 15x10 rims with 32x11.5 tires ok?
Discussion in 'Wheels & Tires' started by Hillbilly Zombi, Aug 5, 2009.
  1. Aug 5, 2009 at 4:34 PM
    Hillbilly Zombi
    Hillbilly Zombi [OP] Well-Known Member
    Wilmington, NC
    01 2.7L Tacoma 4x4
    B5100's all around + Fabtech full length aal + diff. drop. Eagle Alloy 15" wheels with 32" BFG AT's. Custom built skid plate, Rhino lined bed, Westin bars, Husky liners.
    Will it be a safe combo? How about tread wear? Thanks
  2. Aug 5, 2009 at 4:44 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    tread wear depends on how you drive and what kind of tire. whether you spin them or not, hard cornering wears tires. not rotating, things like that. and im not completely sure on the second gen trucks whether you can go down to a 15 inch wheel.. but i had 15x12's on my 98 and it was fine.
  3. Aug 5, 2009 at 4:46 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    a 15x12 what kind of tire did you have?
  4. Aug 5, 2009 at 4:48 PM
    Hillbilly Zombi
    Wilmington, NC
    01 2.7L Tacoma 4x4
    Well more importantly, is it a safe combination?
  5. Aug 5, 2009 at 4:51 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    i'd go with a 15x8 so you dont have to worry about poping a beed if you do any off roading. 11.5 is a little skinny for a 10 inch rim in my book. i have 33x13.50 tires and i have a 15x8 inch rim
  6. Aug 5, 2009 at 4:52 PM
    98_Mud_bug
    lucedale Ms.
    it was some old biased gumbo mudder ha ha it was supposed to go on a 15 inch wide wheel but i put them on 12's i took it off after i slung rocks into both my side mirrors and busted them out.. and it should be safe as long as you dont bash on it and treat it like a baha truck or anything.. but it will make things wear out faster.. its alot more tire than stock.
  7. Aug 5, 2009 at 4:54 PM
    Hillbilly Zombi
    Wilmington, NC
    01 2.7L Tacoma 4x4
    I wont be doing any offroading and the I already have the rims and tires. I just hope they will work ok.
  8. Aug 5, 2009 at 4:56 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    oh well then ya they will work.
  9. Aug 5, 2009 at 4:56 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    oh damn thats a bit ridiculous haha
  10. Aug 5, 2009 at 4:56 PM
    98_Mud_bug
    lucedale Ms.
    depending on the back spacing and offset you may have some rubbing with that wide of a rim and tire combination.. but you may make it away in the clear.. my 15's rubbed like hell. i ended up just taking them off and selling them. easiest way to find out if they work ok is to put them on and drive it.
  11. Aug 5, 2009 at 4:58 PM
    98_Mud_bug
    lucedale Ms.
    yea it was just for showin off in a mud bog.. made it further in 2wd then a bronco on 35's with a hopped up 302. it was a great day until i drowned my truck out and had to replace a bunch of shit.. :(
  12. Aug 5, 2009 at 5:06 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    yep been there done that haha
  13. Aug 5, 2009 at 5:07 PM
    98_Mud_bug
    lucedale Ms.
    mine is not lifted quite as high as yours though.. what kind of lift are you runnin? and have you had any problems?
  14. Aug 6, 2009 at 1:07 AM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    i've got the 3.5 inch fabtech lift. it has the two inch coil overs and then i have a two inch body, the back is lifted about an inch and a half higher than the front also so i have about 6 in the front and like 7 or so in the rear. and no i havn't had any problems really. i was changing my axel boots every year because they had a pretty sharp angle but i bought a differential drop kit and havn't had to change them since and its been over a year. but over all i really like the lift. i have the 33x13.50 toyo mt's and i hate them. dont ever buy those tires. they look cool but they are heave as hell and shake like a mo fo
  15. Aug 6, 2009 at 4:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X2
