Is 2" old man emu leaf springs the same as having 2" lift blocks in the rear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SaltySeaNut, Feb 12, 2020.
  1. Feb 12, 2020 at 10:38 AM
    SaltySeaNut
    SaltySeaNut [OP] Member
    Washington
    2015 Tacoma TRD Sport
    Rancho Quick Lift 1 - 2.5"
    I have a 2015 Tacoma TRD Sport with a 1.5" lift in the front (Rancho) and 2" lift blocks in the rear on factory leaf springs. I would like to replace the lift blocks with the old man emu 2" lift leaf springs but im not sure if it would bring it to the same height, higher or lower than where it is now.
    Have anybody done this to their Taco and what was the outcome.
    6Thick likes this.
  2. Feb 12, 2020 at 10:44 AM
    MemphisTaco
    MemphisTaco Well-Known Member
    Cody
    Nashville TN
    2018 TRD offroad Tacoma
    Kings 2.5 front/rear, ICON RXT, RR2-s, 285/75/17 KO2
    Dakars will net you around 2 inches, depending on the weight you have loaded in the truck. EL095R Dakars will suit you if you dont carry a constant load, EL096Rs will work with a constant load in the back.
    SaltySeaNut[OP] likes this.
  3. Feb 12, 2020 at 2:19 PM
    SaltySeaNut
    Washington
    I usually dont carry constant loads except in the winter time when I carry sand bags for traction.
  4. Feb 12, 2020 at 6:21 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Yes they will.
  5. Feb 12, 2020 at 6:25 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  6. Feb 12, 2020 at 8:19 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    Adding a 3 pack (progressive) add a leaf would help but the true replacement is a new set of leaf packs. Most are 1.5-2" unless states
  7. Feb 19, 2020 at 7:09 AM
    SaltySeaNut
    Washington
    What U-Bolts are required for EL095R or EL096R?
