Is 2005 motor mount problem a concern on 2.7L
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kslice, Sep 2, 2012.
  1. Sep 2, 2012 at 10:57 AM
    Kslice
    Kslice [OP] Member
    Olympia WA
    05 regular cab 4x4 5 spd
    Hello, I have been reading a bit on the motor mount failures on 2005 tacomas. Is this something to be concerned about on my 4 cylinder 05. 67000 miles and mounts look good besides some sloppy welds. Is this something I should be concerned about/do preventative reinforcement on? Thanks in advance!
  2. Sep 2, 2012 at 11:00 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    i did some research on this issue before i bought mine, i believe this issue is only related to the 4.0 liter motors. i'd imagine because of the excess weight.
  3. Sep 2, 2012 at 6:01 PM
    Kslice
    Kslice [OP] Member
    Olympia WA
    Thanks for the reply! I am hoping that this is the case. A little reassuring!
  4. Sep 2, 2012 at 6:04 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    I've only heard of Mount issues on the 4.0L . The 2.7 L should be fine
  5. Sep 3, 2012 at 12:17 AM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    The 2.7 seems to be safe from alot of issues. No ticking, no broken mounts, etc
  6. Sep 3, 2012 at 12:21 AM
    TRDsport253
    TRDsport253 Well-Known Member
    Edgewood, Wa
    2021 TRD sport 4x4
    TRD Wheels TRD Skid plate
    where do you check the mounts for the v6?
  7. Sep 3, 2012 at 8:19 AM
    TacomaBuzz
    CT
    Check where the mount is welded to yor frame. look for cracks in the weld
  8. Sep 3, 2012 at 8:31 AM
    Kslice
    Kslice [OP] Member
    Olympia WA
  9. Sep 4, 2012 at 9:05 AM
    shemp
    shemp Well-Known Member
    I thought that the 4-cyl was just as heavy as the 6 due to cast iron block vs aluminum....???
    4.0 puts out more power, which I presume to be the reason for the caved in motor mounts.
    Edit: never mind, 6-cyl is 90 pounds heavier.
  10. Sep 4, 2012 at 10:18 AM
    Kslice
    Kslice [OP] Member
    Olympia WA
    Interesting, I would think that with only a 90 lb difference it would still be a concern. But I guess the significant difference in torque and Hp makes the difference. Whatever the case the mounts on my 4 banger look solid for now. A friend told me that this was only a problem in the salt belt too.
