Is a 12k winch overkill?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Scott17818, May 14, 2020.
  1. May 20, 2020 at 12:20 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Chances are you already know this with prior winch experience.
    Doing a 1 to 1 is fine. 3 to 1 is better and so on for the amount of pulling capable.
    The winches I have used at work are 30K. The vehicles weigh minimum 45k. Meaning you have to use at least a 2 to 1 ( if you can use a 3 to 1) for self recovery.
    Have also used a 12k winch on a roughly equivalent weighted vehicle. 3 to 1 it is.
    Edit: keep in mind the full load of the winch is with the line fully out. Each wrap reduces the pulling power by a %. Can't remember off the top of my head what it is per wrap but keep that in mind. Also lays more capability to a 3 to 1.
  2. May 20, 2020 at 1:36 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
  3. May 20, 2020 at 1:52 PM
    TurboFire10
    TurboFire10 Well-Known Member
    Erik
    2018 TRD Pro
    ARE Revo, RCI rock sliders
    Using a snatch block doubles the winch capacity according to my Smittybilt X20 instruction booklet. So that’s 20k pulling power on a 7k truck..I think you’ll be fine. A single line had no problem pulling mine up steep and technical terrain.
    Dirk Diggler likes this.
  4. May 20, 2020 at 2:51 PM
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    I'll also give a thumbs up to Warn, and as also said a quality kinetic rope is handy to have in your recovery bag. Also, take a look at the 7P recovery ring.
  5. May 20, 2020 at 2:55 PM
    Clymber
    Clymber Well-Known Member
    Vermont
    Trd
    You have to consider the heaviest vehicle in your group when getting a winch. A fully loaded truck stuck in the mud takes a lot of pulling power to get out
    C41n and Dirk Diggler like this.
  6. May 21, 2020 at 1:07 AM
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    This is a great post. It's important to note the amount of loss in power from each wrap of winch line is significant. In the link from warn below they show a 15% loss per wrap. A 8k winch fully wrapped has only 5200 pounds of force. It's also a great explanation of why.
    https://www.warn.com/warn-winch-performance-specifications-pulling-capacity-by-layer
    Dirk Diggler[QUOTED] likes this.
  7. May 21, 2020 at 1:20 AM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    I wouldn't go less than a 10k winch , those are my plans anyways, and add some snatch blocks like mentioned up above.
  8. May 21, 2020 at 5:34 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Good info. Also, people need to remember to get the correct size snatch blocks, both for their cable size, as well as the rating on the winch and the max # of blocks they plan to rig up.
    Here is a short, but helpful article:
    https://offroadrecoveryguide.com/choose-right-snatch-block-winch/
    C41n likes this.
  9. May 21, 2020 at 6:04 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    You can never have too much winch but you won’t find a good one at your price point. Recovery is too important to skimp on.
  10. May 21, 2020 at 6:06 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    TRD4X4TOY likes this.
  11. May 21, 2020 at 6:39 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    That's what me tinks!
  12. May 21, 2020 at 6:48 AM
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Bingo for some reason I thought it was 12% but did not want to throw out a number that wasn't accurate. Good thing too because I was wrong
  13. May 21, 2020 at 6:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    the smittybilt x20 10k and 12k winch are the same exact winch from a physical standpoint. The only difference is the gearing. So the 12k winch will fit since all these bumpers on the market are designed around a 9.5k/10k winch. If my 9.5 winch shits the bed I'll make the jump to a 12. The winch won't have to work as hard and it's less draw on the electrical system.
    I had this debate with someone one time and all things equal, comparing the X20 10k to 12k the difference was 50ish amps in draw during the pulls being compared.
    Greg.Brakes.Tacos and SR-71A like this.
  14. May 21, 2020 at 6:57 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    I run the X20 12k. Used it a couple times over the winter to pull fullsize vehicles out of ditches. No complaints.
    There's a certain person on this forum that winches more than he drives and he runs a smittybilt winch with no problems.
  15. May 21, 2020 at 7:01 AM
    #35
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    If you got the budget for it (and you can verify with another member that it fits) then go for it. But a smaller, cheaper winch with a good pulley block or ring will do just as well IMO
  16. May 29, 2020 at 4:39 PM
    #36
    TX_Taco88
    TX_Taco88 IG: 4lo_taco
    Jeremy
    WA
    '18 4x4 TRD-OR DCLB
    KINGS, Bruteforce armor, Falcon wheels
    Nice, I'm guessing you have used it. Is it really slow or does it have a decent amount of power? happen to know the weight of it?
