is a 3" revtek lift with a 285/75/16 on stock wheels possibile without rubbing??
Discussion in 'Wheels & Tires' started by redline929_e, Oct 4, 2007.
  1. Oct 4, 2007 at 8:38 PM
    redline929_e
    redline929_e [OP] Member
    i would like to us 285/75/16's on my stock trd wheels with a revtek 3" lift. i understand there is still some rubbing with wheels that have 4.5" backspacing but only when turned all the way and hitting a bump pretty hard. will i have to remove the oem mudflaps?? fender trimming?? or use wheel spacers?? if it does rub will it be on the frame?? a-arm?? or just on the outside inner fender?? any help will be much appreciated. thank you!!
  2. Oct 4, 2007 at 9:27 PM
    jmurf21
    jmurf21 New Member
    2007 PreRunner TRD Off Road Package
    Tinted Windows, Custom Billit Grill, Shaved Decals, Chrome Door Handels
    im not quite sure with that size wheel........does anyone know if the 285/70/17 would rub? that might be a better fit, but im not sure
  3. Oct 5, 2007 at 12:22 AM
    toco389
    toco389 New Member
    99 TOCOMA SR5 V6
    AFE COLD AIR BORLA HEADER BACK TRD SUPERCHARGER.BBK, LIFTED 3 INCHES ON 33'S. LOCKRITE IN THE DIFF.
    wow lol you must be looking for the same look i was! i have the 3" revtek lift with 285x75x16 and they sometime rub when turned locked. yet all i had to do was very minor trimmimg to the inner fender well (just plastics) it clears them nicely
  4. Oct 22, 2007 at 9:26 PM
    redline929_e
    well i did it! i used the revtek 3" lift and stock wheels with pro comp extreme mt's in a 285/75/16. i had to use a 1/4 inch wheel spacer because the tires were only about an 8th of an inch away from the a-arm. now they only rub when turned all the way on the upper a-arm but only on the side wall of the tire and very little.
  5. Oct 22, 2007 at 9:28 PM
    redline929_e
    by the way i got to keep my mudflaps,did not have to trim anything and do not have any rubbing when turning and hitting a bump at the same time!
  6. Oct 23, 2007 at 10:04 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    you need to post some pics, i'd love to see your setup
  7. Feb 9, 2015 at 8:37 PM
    MarineNick
    MarineNick Member
    Nick
    Texas
    '12 Prerunner
  8. Feb 10, 2015 at 11:16 AM
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    Well this thread is 7 years old and sum. OP last active is back in 09. Your going to wait a long time for those pics man.
