Is a gasket needed for the gear box?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DaGo Tacoma, Feb 21, 2020.
  1. Feb 21, 2020 at 2:36 PM
    DaGo Tacoma
    DaGo Tacoma [OP] New Member
    2008 Tacoma Prerunner
    I am changing out my clutch on my 2008 Prerunner 4 cylinder Tacoma. Before removing the transmission the gear shifter had to be removed. The way I did this was to remove to top of the gear box where the gear shifter is. When I did this I noticed a gasket. Do I need a replacement gasket or can I just use black silicone to create one?
    Here is a photo of the gear box that I am referring to.
  2. Feb 21, 2020 at 3:47 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    You will be fine using a RTV (form in place gasket). Toyota uses it on a lot of the machined surfaces anyways. Just make sure the surfaces are clean and dry. Also, too late now, but I'm fairly positive the shifter could have been removed with a simple clip under that rubber boot.
    whatstcp and DaGo Tacoma[OP] like this.
  3. Feb 21, 2020 at 5:36 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    And just use a nice thin film like mayo on your bread thick, not a big thick bead.
    DaGo Tacoma[OP] likes this.
  4. Feb 21, 2020 at 10:08 PM
    DaGo Tacoma
    I did see the clip but it was a bit too late. Lesson learned for next time....really appreciate the tip on just using the RTV and how much to apply. :)
  5. Feb 22, 2020 at 12:02 AM
    TacoTuesday1
    SoCal
    I hear it's just something like Permatex Black RTV, widely available including sellers like Home Depot
  6. Feb 22, 2020 at 10:48 AM
    captaintofuburger
    captaintofuburger Well-Known Member
    2011 Base 4wd 4banger
    Just clean it real well, use a plastic putty knife if needed. RTV will be just fine.
  7. Feb 24, 2020 at 6:07 AM
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    There's definitely a gasket used here. Whether to use RTV instead is your call, but FWIW the main cases of the transmission are sealed with RTV and not gaskets at their joints.
