Is an Axle Swap Possible?
Discussion in '5 Lug' started by pyro13g, Jan 3, 2011.
  1. Jan 3, 2011 at 1:02 PM
    pyro13g
    pyro13g [OP] Well-Known Member
    Will
    Florida
    07 Tacoma Access Cab 4-CYL 5-Lug
    2.5" Lift, Add A Leaf, ridding on 30's, Sound Mat in floors and doors
    I have an 07 Tacoma 5-lugger and I was thinking of swapping the axle for a six lugger axle that way i can have the axle under the leave springs, get a better gear ratio for my bigger tires and I think all i would need to do is get the proper ubolts and mounts as well as new shocks and just hook it up....
    Has anyone tired this and is it even possible? It seems to be cheaper than me getting the rear diff re-geared
  2. Jan 3, 2011 at 1:05 PM
    98tacoma27
    Ben
    Not Beech Creek
    Did you forget about the two new rims you're going to need?
  3. Jan 3, 2011 at 1:08 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    why not just regear to whatever you want. your 3.15 now just go up to 4.10 or 4.56
  4. Jan 3, 2011 at 1:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    And regearing should be cheaper than all that other stuff.
  5. Jan 3, 2011 at 3:09 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Plus theres a reason everybody converts to Spring under axle.... Just get a new leaf pack and stay that way.
  6. Jan 3, 2011 at 3:12 PM
    jandrews
    '09 FourDubDee TRD OR
    Uh...if they're going LT. Some of us don't have the remotest interest in LT activities. What if the OP's a crawler?
  7. Jan 3, 2011 at 3:26 PM
    ktmrider
    Junk
    but lets consider he has a 2wd 5 lug
  8. Jan 3, 2011 at 5:09 PM
    Siebler
    CJ
    Portland, OR
    yeah being that hes a 5 lug I doubt that he is a crawler. I first hand know that even if locked locked 2wd doesnt crawl well enough to build the truck to do that.
    Other than LT the benefits of SUA include less axle wrap, who doesnt want that? Personally im not a fan of my rear end catching up with me after I come to a stop....
  9. Jan 3, 2011 at 5:18 PM
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    and I'm not a fan of hanging up my leafsprings on the rocks and shearing ubolts off :p
    But yeah to the OP, it should work out to be cheaper to just do the re-gear unless you can pull an axle and rims off another truck for very cheap
  10. Jan 3, 2011 at 5:30 PM
    jandrews
    This:
    SUA has its advantages. So does SOA. Depends on what you want to do with your truck. Just pointing out that not "everyone" converts to SUA.
  11. Jan 3, 2011 at 5:37 PM
    Siebler
    CJ
    Portland, OR
    true its not for everybody but If you hang up your leafs on a 2wd chances are your gonna be stuck. Probably why ive never had a problem with my SUA, I dont drive it like a 4wd. I may be LT but mostly thats because I was sick of breaking the crappy 1st gen 5 lug suspension, not because I run the desert and not forest roads. In fact my truck sees far more trails than high speed stuff.
  12. Jan 4, 2011 at 5:29 AM
    pyro13g
    Will
    Florida
    Thanks Guys! Im not a Crawler, I do a lot of off roading and Im tired of having a low stance and a cheap way to get some lift would be to go SUA plus the gearing would be better in a 6-Lug axle than mine. I was doing some research and found that most places wanted to charge me a minimum of $250 for the labor and another $300 for parts. I think this is too high and i could swap axles for cheaper im sure. But on the other hand swapping axles could run into some issues which would most likely cause me more money in the end....
    Ill just do a re-gear... so would 4.30 be a good ratio?
  13. Jan 4, 2011 at 7:10 AM
    viperstd
    Maryland
    What size tires?
  14. Jan 6, 2011 at 4:57 PM
    pyro13g
    Will
    Florida
    30 x 9.5x 15 and im looking to upgrade in the future to 31's
  15. Jan 6, 2011 at 6:07 PM
    comiesutra
    comiesutra Well-Known Member
    Greenwood, IN
    '10 4X4 Silver AC SR5 Manual
    MonsterKnobs.com shift knob, Sony MEX-BT3900u
  16. Jan 7, 2011 at 7:55 AM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
  17. Jan 7, 2011 at 9:46 AM
    McJosh
    Josh
    Chandler
  18. Jan 7, 2011 at 3:46 PM
    McJosh
    Josh
    Chandler
    so it'll cost $1,300 to re-gear and another how much to lock?
  19. Jan 7, 2011 at 4:49 PM
    McJosh
    Josh
    Chandler
    so our axle type is the last 8.4"?
    and still, total is about $1200.
    The total chaos LT kit is $707 but it doesn't include shocks. :(
  20. Jan 8, 2011 at 4:47 PM
    McJosh
    Josh
    Chandler
    i think it'll be more important to re-gear and lock first. I heard that the detroit true tracks is a better locker for street and off road use and only for a couple bucks more. And buying everything separate and using the old 3rd member saves money. ;)
