Is an inline fuse a must for tapping into accessory wire at radio?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazze2005, Jun 14, 2011.
  1. Jun 14, 2011 at 9:24 PM
    blazze2005
    blazze2005 [OP] Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Is it necessary to put an inline fuse when tapping into accessory wire at radio? I will be doing this to get power for my sirius radio...
    If so what size fuse should I put in the holder?
    The radio is a sirius starmate replay that runs on 9-16 Volts
    Thanks for any info...
  2. Jun 14, 2011 at 9:56 PM
    justinhw
    justinhw Well-Known Member
    Turlock, CA
    06 Regular Cab 4x4 2TR-FE
  3. Jun 14, 2011 at 11:47 PM
    JKD
    JKD Well-Known Member
    Chances are good that the Sirius receiver doesn't use a lot of current. Look for how many amps it draws in normal useage, and get a fuse that has a slightly higher rating -- as long as it isn't higher than the smallest wire in the circuit can safely handle.
  4. Jun 14, 2011 at 11:50 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Simply put, it is not absolutely a must but it would be like not having a fire hydrant in your house. Chances are you won't need it, but in the case that you do and you don't have it you'll be screwed.
    Also if the accessory wire is already fuse protected to a number just above how much the accessory and the radio draw together then you will also be fine that way :D
  5. Jun 15, 2011 at 6:48 AM
    blazze2005
    South Jersey
    Ok I just found out the sirius radio had a 2amp glass fuse in it originally,so would a 3amp be ok? The accessory wire I taped into for the radio is on a factory 7.5 mini fuse...thanks again guys
  6. Jun 15, 2011 at 9:08 AM
    blazze2005
    South Jersey
  7. Jun 15, 2011 at 9:15 AM
    blazze2005
    South Jersey
    I'm gonna stick with the 2 amp fuse....
  8. Jun 15, 2011 at 9:59 AM
    Drunknsloth
    Retribution
    South West
    Haha I meant fire extinguisher :D
