Is any damage done?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Xewkija631, Dec 7, 2010.
  1. Dec 7, 2010 at 7:26 AM
    Xewkija631
    Xewkija631 [OP] Well-Known Member
    LI,NY
    2011 BLACK DC TRD OFF ROAD
    I have seen users talking about not driving right away untill their engine is warmed up first, does cold starting and driving instantly damage the engine or anything? Are their some benefits? Besides your truck being nice and warm.
    Thanks
  2. Dec 7, 2010 at 7:31 AM
    cc350
    cc350 Retired Member
    Allowing a cycle to warm up fluids in engine and transmission is a good thing.
  3. Dec 7, 2010 at 7:32 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Search "warm up". Not trying to be a dick but there have been a lot of threads on this and very mixed opinions. Personally, I let the truck warm up. My mentality is oils thicken when they're cold so why make the engine work harder when it's stone cold. If running that cold wasn't an issue, they wouldn't make block heaters for gas engines. Again, my opinion and you'll get plenty of responses saying the exact opposite and some against letting a cold engine idle, etc. Basically get ready for a crapstorm of opinions.
  4. Dec 7, 2010 at 7:43 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    if it is frozen outside, i tend to let it warm up. if not, i drive very very slowly away.
  5. Dec 7, 2010 at 7:49 AM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    I give it about 30 seconds when it is cool, maybe 45-60 seconds when it is cold. Anything more than that are you are wasting gas and time. Although I drive like a little old lady until it is all the way warmed.
  6. Dec 7, 2010 at 8:18 AM
    Yota Newb
    Yota Newb Well-Known Member
    Bryan
    Indiana
    2010 5-Lug Regular Cab 2.7L 5 Speed
    Try sitting a bottle of the oil you use in your truck outside in the cold overnight and examine it. I always let it run for at least a full minute at idle. It can't hurt. Thousands of RPM's and sub zero temps, I don't take any chances.
  7. Dec 7, 2010 at 8:31 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    There is so many different theories on this. From what I understand give it about 30 secs and take it slow, keep the rpms down, untill you feel heat from the heater. Then your good to go. Sometimes I'll warm mine up if I have snow and ice just to make it easier to scrape. I have actually heard its bad for it to just sit there and idle. But you will probably get alot of different opinions on this.
  8. Dec 7, 2010 at 9:00 AM
    kessler89
    kessler89 Well-Known Member
    OH
    12' Pro4x 6MT
    TBA
    my Z06 had a oil temp gauge, you wouldn't believe how long it took the oil to get up to operating temp (140-180deg) i drove it on a cool fall day once let it warm up for about 5 min and then took off, drove almost 10mi before the oil temp came up to normal
    on that note if i'm home or anywhere but work i start my truck and try to let it run for 5min, i dont care about burning just that little bit of extra gas, just cause your temp gauge is going up doesn't mean your oil temp is, it takes ALOT longer, if i'm at work i usually start it and let it run for a min or 2, then i have a idleing crawl thru the parking lot just trying to get out of there that lasts a couple min, i drive it like a grandma anyways
  9. Dec 7, 2010 at 9:24 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    I always wondered about this, hopefully it doesnt hurt it to bad considering if my pager goes off and I have to get to the FD I start my truck and go.
  10. Dec 7, 2010 at 9:25 AM
    Xewkija631
    LI,NY
    Thanks for the suggestions, it has been getting quite cold here but I guess I will let it run for a bit just to be on the safe side.
  11. Dec 7, 2010 at 9:26 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    I try to let mine run for a few minutes before going anywhere but like I said in previous post sometimes its
    1) Page goes off
    2) Boots on
    3) Start truck
    4) Get to FD quickly
  12. Dec 7, 2010 at 9:33 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    There are many times I have the truck started, in gear and driving away less than 3 seconds. Never had an issue.
    However, I do not make a habit of doing that...only when I'm late for something. And I don't think I would do it on a sub-zero day.
    I also don't rev it out when I first take off.
  13. Dec 7, 2010 at 9:35 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    I dont either (rev it)
    I like it idle out the drive to the stop sign usually roll the stop sign (depending on what time it is, this is usually midnight to 4am) I only do it if its safe.
    Then I give it slight gas to the light and get to the FD
  14. Dec 7, 2010 at 10:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Once propper oil pressure is reached (in about 5 seconds, or less), no damage will be done from driving off. The best way to warm up the engine, is by driving it.
  15. Dec 7, 2010 at 10:17 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Good stuff how did you learn this?
  16. Dec 7, 2010 at 10:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    From friends of mine that engineer, and build engines, tearing them down myself, and doing oil sample analysis. What hurts an engine, is metal on metal contact. The engine doesnt care what the outside temp is, but rather, getting it up to temp as fast as possible. Warming it up slowly (idling for long periods first thing in the cold), allows water to build up in the crank case. Water is very bad for engines. The faster the engine gets warmed up, the faster it can boil off the water, and remain happy.
  17. Dec 7, 2010 at 10:37 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    2 things
    1) So its bad to let it sit and idle if its cold?
    2) I love your sig about the bitching lol
  18. Dec 7, 2010 at 11:05 AM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    +1. BMW engineers also agree with this. It's in the owners manual to drive the car to warm it up and just to keep the RPM's lower for a few minutes.
    I guess people could argue with this based on their own research and development of engines.
  19. Dec 7, 2010 at 11:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive never tested to see if its "Bad", but I do know that more water builds up if the engine is warmed slowly, than if its warmed up quickly. Most manufactures even say to get the temp up quickly. And thanks :)
  20. Dec 7, 2010 at 11:25 AM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Yes. My dad owned an E46 M3 and they sent a letter out to owners (back in 02 or so) stating the best way to warm up the car is by driving it (and staying under the "yellow line" of the tach, which increased with engine temp.
    There are many other vital fluids in the car that have a warm up time (like diffs etc) so just because the engine is warmed up then hammering it isn't the best idea.
