Is it bad to let the transmission drop 2 gears climbing a steep grade?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, Nov 11, 2014.
  1. Nov 11, 2014 at 10:11 AM
    2004TacomaSR5
    2004TacomaSR5 [OP] Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    A buddy of mine told me that driving on the highway in cruise that I should never allow the transmission to kick down 2 gears and rev up real high like they do on steep hills running on the cruise. I never thought it was bad as long as it didn't redline, but am I wrong? Should I kick the cruise off before ascending a steep hill you think?
    He claims he's seen so many engines blow up from doing that.
  2. Nov 11, 2014 at 10:21 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Cruise is for long stretches of light traffic flatland IMO. My mouse motor drops 2 gears at freeway speeds on sustained, steep grades. I wouldn't maintain 5300 RPM for 5 minutes, but with my configuration and 2.7 auto combo that's the name of the game on that kind of road.
  3. Nov 11, 2014 at 10:26 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    It's not the dropping two gears that kills a transmission, it's the heat build up while hunting for gears -- the slippage internal to the transmission while it's in between gears that causes the heat build up.
    Best course of action on a steep grade is to turn off overdrive so the transmission isn't constantly going back and forth between 3rd and 4th.
  4. Nov 11, 2014 at 10:29 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Turn off cruise when going up steep grades.
  5. Nov 11, 2014 at 10:37 AM
    fuballs
    fuballs Well-Known Member
    Ben
    BC, Canada
    07 Double Cab Long Bed SR5
    Leer Canopy, Thule Roof Rack, Aux Fog Lights, okledlightbars.com 30" double row, AUX fuse Box, Tepui Kukenam
    I don't really think this applies to modern cars any more. Just put it in D and let the computer figure it out, cruise control or not.
  6. Nov 11, 2014 at 11:05 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    :eek: People, these days, just don't know how to drive anymore. I'll bet when driving down a steep grade, you ride the brakes all the way until the rotors are glowing, while talking on your smart phone :rolleyes: .
  7. Nov 11, 2014 at 11:08 AM
    T4RFTMFW
    Wat?
  8. Nov 11, 2014 at 11:12 AM
    eazyrider711
    eazyrider711 Well-Known Member
    Jay
    Northern, CO
    Black DCSB T|X Baja
    Do this; ignore the rest.
  9. Nov 11, 2014 at 11:45 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    ^^^^^^ this
  10. Nov 11, 2014 at 12:21 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I also press the ECT button (left of the steering wheel) to make the shift points a bit higher - this also helps if the truck keeps trying to switch between 2nd & 3rd gear.
    This only applies to automatics because of the torque convertor.
  11. Nov 11, 2014 at 12:50 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    better to let the engine sing at a higher rpm for a bit than have the tranny hunting up and down for a gear. If the high rpms worry you slow down a bit
  12. Nov 11, 2014 at 3:34 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    ^^ this.
  13. Nov 11, 2014 at 6:12 PM
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    OK, I'll give an alternate viewpoint of what many are saying - $$$. I always pop cruise off when climbing a steep grade as I'd rather not hum that engine/tranny that long, but I'd also prefer not dropping down to <9 mpg so I can shave a few seconds off my total drive. Not that I have CC in my Taco, but do in my Camry. Flat roads around here are more elusive than a wife that says "Yeah, she's cute, bring her home." Lots of longish grades in both directions means CC goes off and on :)
