Is it ever really necessary to install a lift?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 18TRD_OR, Apr 15, 2018.
  1. Apr 16, 2018 at 2:43 AM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    Sure, a mall crawler lift is pointless and bad for a truck. But what's all this talk about a lift being bad for the Taco? The TRD Pro comes with a 1" lift.
    Sharpish likes this.
  2. Apr 16, 2018 at 3:39 AM
    UplandExplorer
    UplandExplorer Level of crazy: Chukar Hunter
    Turbine Tommy aka Mr.Pickles
    Nor Cal
    2017 White TRD OR DCSB
    mud, bugs, feathers, and dog hairs.
    I’m in a similar category as you, trying to avoid loosing the factory OR ride quality. I run on some rough basaltic “roads” for Chukar Hunting in the high desert areas of CA, NV, OR, and ID. I haven’t lifted yet, run stock tires, do have sliders now for insurance. My factory skids have some dents and scrapes. Running with a topper and dogs +gear I purchased the 612-40 Sumosprings to help with the “Bro-Lean” when loaded (less cost and maintenance than airbags and don’t alter factory ride when unloaded). Next purchase will be aftermarket skids and an exhaust reroute. I’ve got a set of 265/75r16 KO2s ready for next season after I chew through whats left on the factory tires.
    If I end up “lifting” in the future it’ll be to regain factory ride height after adding skids, sliders, topper, bed platform/drawers, kennels, etc... I may have to sacrifice the “soft” OR feel when that day comes, but I hope not! My tenative plan is 1/2” top plate spacer in front and new leaf pack in rear, potentially with 5100/5160s
    Good luck with your quest.
    tonered likes this.
  3. Apr 16, 2018 at 5:48 AM
    dirtyhesher603
    dirtyhesher603 Well-Known Member
    zack
    southern nh
    2018 cement grey tacoma TRD OR ACCESS CAB
    ST MAXX 255/85-16
    I think im in the same boat, but more for money reason...ive been debating whether I want to drop the coin on a lift for my 18 OR. I think for the time being im just going get 255/85-16's and gain the extra 1"-1 1/2" of ground clearance/get a beefier tire and maybe lift it a little bit down the road. personally I don't think for 99% of what your going to come across (especially for what you described you want to do) you would need a lift
    I married my tacoma likes this.
  4. Apr 16, 2018 at 6:03 AM
    Clearwater Bill
    Billy
    Largo Florida
    That's a purdy boy deal (looks only).
    Rake is engineered in for a couple of reasons, including handling.
    As @hiPSI says, other than departure angles, actual net clearance (axle clearance) comes from wheel/tire dia changes.
    OP, if you want some lift, look at a thread I think is called 'the skinny on skinnys.' With the correct OE wheel you can run a 255 80 or 85 tire which is a full 33", no rubbing triming or suspension changes.
  5. Apr 16, 2018 at 6:49 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Tires. Skid plate. Shovel. Portable pump.
  6. Apr 16, 2018 at 6:57 AM
    jeremy5000
    jeremy5000 Well-Known Member
    Philadelphia
    Start with the tires skid plates and/or sliders from @Mobtown Offroad . Then, once your gear is weighing too much for the stock suspension to handle, do a lift. The stock truck is plenty capable and can easily do everything you are mentioning, but the only issue down the road is that if you have a ton of gear, RTT, etc. in the bed, you might want to consider a beefier suspension setup to handle the weight.
  7. Apr 16, 2018 at 7:02 AM
    Hawk45
    Hawk45 Active Member
    Hawk
    Ohio
    2017 Tacoma TRD Sport MGM
    Even though I'm new here, I'm sure this is one of the most asked questions. Unless you plan on doing true OR crawling adventures (not gravel roads to your camp site) then I would say you don't need anything. Just take a look next time you are out camping or wherever you go.. I guarantee you there is someone there in a Prius (hahaha, never fails). That may give you an idea if you NEED a lift or not to get where you are going with one of the already best ORV on the market. As we get older we just find bigger man Lego's to build with. The slope is slippery but for most not necessary. That being said necessity and want are two different things, and if you have the budget and need/want.. go for it. Only you can answer the question if you NEED a lift.
  8. Apr 16, 2018 at 7:17 AM
    GR8APE
    GR8APE Well-Known Member
    You can pick up a low mileage military Humvee for about $16000 which is about half the price of a new Tacoma. Even after you add all the goodies on your new truck the Hummer will still be more capable. Just a thought...
  9. Apr 16, 2018 at 7:22 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    This is how I see it.
    If your in situations that cause you to lift tires consistently when offroading you need a lift kit.
    If your doing trails that keep all tires planted you will not need a lift especially if you have a locker.
  10. Apr 16, 2018 at 7:27 AM
    STexaslovestacos
    STexaslovestacos Well-Known Member
    Sam
    2017 MT TRD OR
    You'll also be completely miserable, because they sorta suck at everything that's not off-roading, and they're too wide for a lot of offroad trails anyway
    The stylin' ex-military offroad vehicle to get is a Unimog, imo
  11. Apr 16, 2018 at 7:31 AM
    GR8APE
    Actually I was just poking a little fun however the Unimog is really a cool vehicle but they are really expensive.
    JayRolla likes this.
  12. Apr 16, 2018 at 7:36 AM
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    Another thing to think about is how much you're lifting the sheet metal (fenders, bedsides etc). A lift with the taller tires you mention will get your expensive painted parts 3" higher which is the reason why I do it. My 4x4 usage is almost 100% to get somewhere (hunting, fishing, camping, etc). If there's an easier way around an obstacle, I take it. Having a modest lift, taller tires and upgraded armor allow me to get more places while avoiding damage.
    Hemibee and I married my tacoma like this.
  13. Apr 16, 2018 at 7:46 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    If you REALLY want to spend money on something much more worthwhile for off roading, go take a one day course on how to properly off road. Picking the correct line through a tough spot is much more effective at preventing damage than pretty much anything else you can do. The reason most people here need a lift and armor is they choose the wrong lines. A pro can take a Prius places that an amateur can't take our truck, and emerge with no damage.
    Hemibee, GR8APE, Cudgel and 1 other person like this.
  14. Apr 16, 2018 at 7:50 AM
    maxus
    maxus Well-Known Member
    2017 TRD OR DCSB V6 MT
    Sure, lifted trucks look great. But I'd guess the majority of folks in here are like me, and use their truck as their daily driver. So, the truck has to be a "jack of all trades", and do most all things reasonably well. Still think your truck needs to be lifted to perform off road? Go back and look at the old Camel Trophy trucks. And look at what those rigs went through. IMO, there are more important upgrades to be done for off-road capability, besides a lift and tires.
    Intrepid, Hemibee and Dirty Harry like this.
  15. Apr 16, 2018 at 7:55 AM
    #35
    BearintheWoods
    BearintheWoods Well-Known Member
    Barry
    2018 Black Tacoma Off Road
    @YOTA 4X4 - Can you really run 255/85 16s on a stock OR? That's like a 33.3" tire isn't it?
  16. Apr 16, 2018 at 7:57 AM
    #36
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    No. You will rub quite a bit. Most run 265/75-16 on stock OR suspension. If you want to go to a 285/75-16 or a 255/85-16 you will need to lift.
    FlyFisherCJ likes this.
  17. Apr 16, 2018 at 8:09 AM
    #37
    STexaslovestacos
    Sam
    2017 MT TRD OR
    There's a whole 60 page thread that disagrees with you. The trick seems to be no mudflaps and the stock OR wheels and suspension. If you move the wheels in the wheelwells just a little bit it doesn't fit.
  18. Apr 16, 2018 at 8:11 AM
    #38
    YOTA 4X4
    YOTA 4X4 Well-Known Member
    2017 Double Cab Off-Road
    OME HD Lift all around, SCS SR8 Rims, 255 85 R16 Cooper ST Maxx, Decked Drawers, 30" Rigid Pro Light bar above bumper on Rago Mounts, Rigid Dually Side Shooters on Rago ditch brackets, Hondo Garage Un-Holey Phone Mount X2, Hondo Radio Knobs AR Bolt Face, Garmin InReach SE GPS synch'ed to Iphone for GPS only mapping, Wet Okole Seat Covers, Husky Liner Contour floor mats, 63 QT ARB Fridge on Alu-Cab tilting slide. GoFastCamper (#41), ARB 2500 Awning with Full Room, Mobtown Off-road Sliders and Full Aluminum Skids.
    Yes and for the life of my i can’t find it right now.... any body help? You CAN run 255 85 R16’s no Lift. The key is these are narrow tires. If you wanna go wider and that tall no dice. Someone please find that thread I’ve been searching for 20 mins i think....
    sierra141 likes this.
  19. Apr 16, 2018 at 8:12 AM
    #39
    Scotty Dosent Know
    Scotty Dosent Know Well-Known Member
    2017 Tacoma DCSB
    Most of the people that do "Overlanding" aka truck camping are never some where that really requires a lift. If you are doing forest service roads and stuff like that the truck bone stock is super capable. Honestly you could probably go most of the places the Overlanding scene goes in an Accord.
    I would get out there and start exploring. If there end up being places you want to go that need a lift get one. If you never need a lift to go where you want to go wont waste the money.
    desperado915 likes this.
  20. Apr 16, 2018 at 8:12 AM
    #40
    STexaslovestacos
    Sam
    2017 MT TRD OR
