Is it necessary to get a new battery if...?
Discussion in 'Audio & Video' started by DSully72, Oct 14, 2010.
  1. Oct 14, 2010 at 7:09 PM
    DSully72
    DSully72 [OP] 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    I FINALLY have everything i need for my subwoofers on the way... I got the box, the subs, the grills, the amp, and the power kit... now.. do i need to get a performance battery? some say i need to get a red top, but some say its not necessary... im running two 4 OHM Kicker CVT8's off a Kicker ZX1000.1 amp.
  2. Oct 14, 2010 at 7:11 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    i would go with a yellow top instead cause they are deep cycle batteries meant to handle increased stress on the electrical system, just my opinion
  3. Oct 14, 2010 at 7:20 PM
    DSully72
    Daniel
    Appling, GA
    but is it really necessary? am i really running that much power?
  4. Oct 14, 2010 at 9:07 PM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '06 DC LB 4x4
    OME lift w/ Dakars & 885's Remote Start w/ window control
    I've ran a red top before... deep cycled it many times. In fact, I had a friend in high school who's dad built electric cars using the red tops... My opinion, unless you're gonna continuously drain your battery and then recharge it, the red top will work just fine.
    On the subject of whether or not you need a battery, Do you actually have issues with your current battery? If not, but you want a little extra "firepower" for your system, get yourself a 1 farad capacitor. If you do have issues with your current battery, then thats another story, and you should indeed get yourself an Optima battery (I would go red over yellow though), but I would still suggest getting a capacitor for the system. Easy to wire in, just put it within a couple feet of the sub amp, the closer the better, in line with the +12v power supply wire, and ground it to the same spot you ground your sub amp (don't wire the amp ground through the capacitor like you do with the +12v supply... keep your grounds as short as possible)
  5. Oct 15, 2010 at 4:58 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    No...you're not. You might be running "1000watt amp" but your subs will never see close to that much power. Those 8's will catch fire before that happens.
  6. Oct 15, 2010 at 5:29 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I ran 2 tens off a 1000w amp and used the stock battery and everything worked fine and they still hit hard!
  7. Oct 15, 2010 at 5:59 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    NO, you do not need a new battery. I have run ridiculous car audio in all of my vehicles and never have needed a new battery. When it's time to replace your battery, that's the time to get an optima. But you don't need one
  8. Oct 15, 2010 at 11:23 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Agreed. That's what I did in my Lexus IS300. The thing that matters most in any event is the alternator anyways. It's the thing that's MAKING the power. The battery is just the holding tank ;)
  9. Oct 15, 2010 at 2:02 PM
    Detective_Dan
    Colorado Springs
    it is not "necessary" its just something i did to give a helping hand. it also has a lot to do with how much power the alternator can put out. our trucks have a much better alternator than a little honda civic, thats why i ran the yellow top in my old civic
  10. Oct 15, 2010 at 2:18 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Just get a capacitor
  11. Oct 15, 2010 at 4:26 PM
    Detective_Dan
    Colorado Springs
    capacitors dont work as well as everybody thinks, they do help, but a SECONDARY battery is a better option in my experiences
  12. Oct 15, 2010 at 4:31 PM
    Shemicals
    Shemicals Well-Known Member
    Concord - East Bay CA
    '07 5-Lug Black Sand Pearl Access Cab 2WD
    Build Page
    with two 8's at 1000 you will not need a new battery. larger subs at higher rates with 1 amp for the subs and 1 for the doors however will require a performance battery. i have 2 d312's along with eclipse speakers and an eclipse double din + leds. i needed a new battery almost immediately as my battery died beyond jump. now with the red head it rapes. you wont need a capacitor no matter what they say (unless of course your running 4 15's ea with its own amp :) ), the car is too new
  13. Oct 15, 2010 at 5:38 PM
    DSully72
    Daniel
    Appling, GA
    sweet thanks guys. yall just saved me a lot of money =) lol
