Is it normal for the throttle body to be slightly ajar when not powered up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saugus, May 17, 2019.
  1. May 17, 2019 at 3:24 PM
    saugus
    saugus [OP] Well-Known Member
    I have removed and cleaned the throttle body and have to physically push my finger on the valve plate slightly to close it 100%. It bounces back to ajar when released. Is that standard? I guess I'm wondering if the spring action is supposed to keep it fully closed or if the actuator does that. Maybe noob question.
    2.7 L
  2. May 17, 2019 at 6:38 PM
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    Mine does it too. I think it's like that so the engine has air when starting
    b_r_o likes this.
  3. May 17, 2019 at 7:03 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    yes, it's for the fail-safe so you can drive it in limp mode if the ECM or throttle body actuator fails.
    b_r_o and MurderedTacoV2 like this.
  4. May 17, 2019 at 10:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the CEL is not on and the engine idle speed is normal on startup i wouldnt worry about it
  5. May 19, 2019 at 3:58 PM
    saugus
    thanks, it's cleaned up nicely now. It idles fine.
  6. May 19, 2019 at 7:07 PM
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    This is also done on purpose to prevent the throttle body from freezing shut in place during cold winters in the event you have some moisture in the air intake system. It does happen and I've seen it happen, damaging the electronic motor that opens and closes that throttle body; requiring you to replace the entire throttle body.
    Perfect example is windshield wipers; if you leave them down during a cold wet night and the wipers freezes to the windshield; you go turn them on in the morning and pop you break something; kinda the same ordeal. Just its most likely will happen to wipers and less likely for throttle bodies.
    b_r_o likes this.
