Is it normal to feel every crack in the road? Even the tar that they fill cracks with?!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 757yotas, Nov 13, 2019.
  1. Nov 13, 2019 at 1:21 PM
    757yotas
    757yotas [OP] Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Ever since I've had the truck it rides so firm, if I have a drink the the center it spills everywhere. It is so firm even with multiple suspension set ups! So far I have tried the following set ups -
    5100 with OEM trd offroad coils set to 2.5"
    5100 with ome 2887 on lowest setting
    5100 with ome 2886 on lowest setting
    Toytec Boss coilover with 650lb Eibach coil
    The rear is OME dakar packs with Toytec Boss shocks to replace the old 5100s it had before.
    My tires are 285/70r17 load E Nitto Exo Grapplers at 32 psi, I tried to lower it down to 27 psi but the only thing that changed was mpg so I went back to 32
    Need advice because I dont understand how it can be so firm with literally everything. Even coils that are over 50lbs apart in weight
  2. Nov 13, 2019 at 1:27 PM
    mac84
    mac84 Well-Known Member
    Alabama
    2015 Tacoma TRD Sport 4WD MGM
    Load Range E's maybe?:confused:
  3. Nov 13, 2019 at 1:28 PM
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    Gunshot-6A, 4x4_Angel, mlcc and 6 others like this.
  4. Nov 13, 2019 at 1:30 PM
    757yotas
    Virginia
    2007 TRD Sport
    I thought that could be but I dont see how it can have that big of an effect
  5. Nov 13, 2019 at 1:32 PM
    mac84
    Alabama
    I will admit that stuff like that drives me NUTS
    Alexely999 likes this.
  6. Nov 13, 2019 at 1:33 PM
    eon_blue
    Azusa, CA
    E rated tires really do kill the street ride on these trucks, they are simply overkill for the majority of Tacomas. I run Es on my 1st gen and the street ride can be pretty brutal even with Kings up front and Icons in the rear. But the trade off is that they are far more durable offroad than a lighter load tire.
    Once I air them down to 15psi or lower, everything is smooth as butter and I can really feel how well the suspension works. But on the street, with 32psi in them...they are rough. Just the way it is. There's a brutal speed bump in our work parking lot that I have to take a <4mph or else it feels like I'm slamming into a curb.
    I would suggest switching to a C rated tire if you don't need the E load ones
  7. Nov 13, 2019 at 1:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Camber bolts seized?
  8. Nov 13, 2019 at 2:03 PM
    757yotas
    Virginia
    2007 TRD Sport
    No I just replaced them not long ago, I might just have to get rid of the nittos and get some P rated wildpeaks since the truck only goes in sand
    Torspd[QUOTED] likes this.
  9. Nov 13, 2019 at 2:05 PM
    eon_blue
    Azusa, CA
    Be careful airing down P rated tires in sand...another good thing about E's is that you can air them down to under 10psi and not worry about rolling off the wheel or blowing a sidewall...P rated tires are going to have much weaker sidewalls
  10. Nov 13, 2019 at 2:10 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    It’s the Dakars.
    MolonLabeTaco and AR15xAR10 like this.
  11. Nov 13, 2019 at 2:12 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Lower the tire pressure.
    Torspd likes this.
  12. Nov 13, 2019 at 2:17 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ also having your 5100's set at 2.5 doesn't help either.
  13. Nov 13, 2019 at 2:22 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    5100s are stiff, E rated tires are stiff,
    but the Dakars are what’s breaking your spine the most ha. Try driving a Pickup with OEM leaf springs. See if you notice the difference.
    757yotas[OP] likes this.
  14. Nov 13, 2019 at 2:23 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    2.5” BILSTEIN on TRD OFF-ROAD springs with E-Rated tires...there’s your answer. I have the same up with TRD SPORT springs and it’s much better than stock.
  15. Nov 13, 2019 at 2:24 PM
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
  16. Nov 13, 2019 at 2:24 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It's the E rated tires. I'm presently running those mistakes. Fauckers wear so slow, too.
  17. Nov 13, 2019 at 2:25 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    It’s a truck,man. What did you expect?
    honda50r and PoweredBySoy like this.
  18. Nov 13, 2019 at 2:27 PM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    I have Dakar leafs with TRD Pro Bilsteins and mine drives the same way, I attribute a little of this to the digressive valving of the shocks and a lot of it to the leaf pack being super stiff
  19. Nov 13, 2019 at 2:38 PM
    cpc
    cpc Well-Known Member
    MASS/ESSEX COUNTY
    TRD PRO
    cbi front receiver, rigid lights, leitner designs, mobtown sliders, Brute Force Fab
    650lb Eibach coil? stiffer than stock, do you have an aftermarket front bumper?
  20. Nov 13, 2019 at 2:47 PM
    757yotas
    Virginia
    2007 TRD Sport
    I have toytec boss now
