Is it possible for spark plugs to take a dump at 28K?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlueT, May 6, 2010.
  1. Jun 13, 2010 at 6:24 AM
    75thrangertaco
    75thrangertaco Sua Sponte! RLTW
    charles
    casper wyoming
    procomp 6 inch co lift ,305/55/20 xtreme a/t tires,4.88 gears ,,grill shell painted white billet inserts.Trd cat back ,
    deff change the plugs as its time and it wont hurt.have your fuel pressure and volume checked. a lean condition will not always set the cel, also check for a vacume leak under the hood.this will also cause a lean condition. lean will give you the exact symptoms you are describing.
  2. Jun 13, 2010 at 6:30 AM
    75thrangertaco
    charles
    casper wyoming
    sometimes the manufactuer supercedes the part number because they are buying from a different source. or they redesign it so it will fit multiple models. the idea is to carry the least amount of part numbers and service the max amount of models, hence lowering the overhead of inventory
  3. Jun 13, 2010 at 12:43 PM
    JKD
    JKD Well-Known Member
    The primary benefit of platinum and similar plugs is extended life (of the plug). There is no advantage in performance/mileage over new plain copper plugs of similar design (electrode shape).
  4. Jun 15, 2010 at 7:23 AM
    Jeremiah Stewart
    Jeremiah Stewart New Member
    Jeremiah
    Colorado Springs, CO
    06 4X4 AC Impluse Red
    TRD Intake, Momo Pedals, Flowmaster Duel Exhaust
    There are Benefits when you start looking at different designed plugs. Some plugs with the smaller electrode produce a better spark. Plus you get the added added benefit of longer life of the plugs. hope this info helped out.
  5. Jun 17, 2010 at 7:31 AM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Thanks JKD and Jeremiah, good info.
  6. Jun 17, 2010 at 8:04 AM
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    Expect to change your plugs every 30k
