Is it possible to add another 1" lift to my current ome/dakar lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AgentSicker, May 7, 2013.
  1. May 7, 2013 at 9:00 AM
    AgentSicker
    AgentSicker [OP] Member
    Seattle,Wa
    I have searched around and havnt found an answer... I currently have a 3" OME Lift with dakar rear leafs. 887 coils up font. Its a 2007 Double cab offroad. i would like to add another inch lift front and back. Is there anything i can add to my current setup to get another inch out of it? any help would be awesome. thank you
  2. May 7, 2013 at 9:03 AM
    Large
    Large Red
    Body lift, and do you mean 886s?
  3. May 7, 2013 at 10:58 AM
    AgentSicker
    Seattle,Wa
    yes im sorry. that was a typo. i have the 885 springs up front. i was thinking about a body lift but dont like the gap in the rear bumper. is there any problems going with a 1 inch body lift? like the steering shaft and whatnot
  4. May 7, 2013 at 11:02 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    If you're 4x4 3" is the most you can go. Prerunners could get a little more, but its not really recommended since you start pushing your suspension towards it's limits then.
  5. May 7, 2013 at 11:02 AM
    bzzr2
    bzzr2 Well-Known Member
    that is a lot of work for 1 inch of pretend lift. you gain nothing unless you want to do this to make room for larger tires.
    do you already have top plate spacers? if not you can add this. you can add the OME add a leaf to you dakar pack. both of these items can net approx 3/4inch of lift.
  6. May 7, 2013 at 11:24 AM
    AgentSicker
    Seattle,Wa
    ya im 4x4 . yes i have the smaller ome top plate spacer on the fronts. i may get the thicker top plate spacer and maybe do the dakar add a leaf in the rear.i currently have 285/65/16 km2's. thanks for your help guys!
