Is it possible to have led LB switch turn off when truck is off
Discussion in 'Lighting' started by Dirtboyz, Nov 22, 2015.
  1. Nov 24, 2015 at 2:32 PM
    TRSJimmy
    TRSJimmy All I Do Is Nguyen
    Jimmy
    Gainesville, GA
    12' Mall Crawlin Peerunner
    Ah, I see. I was talking about Joe's wire harness.
    Blackout14 likes this.
  2. Nov 24, 2015 at 2:33 PM
    TRSJimmy
    Jimmy
    Gainesville, GA
    I have a blue sea fuse block. Definitely makes it a lot easier and cleaner in the engine bay
  3. Nov 26, 2015 at 12:54 AM
    Dirtboyz
    Dirtboyz [OP] Well-Known Member
    Spanaway, WA
    DCSB trd sport 4x4
    Front bilstein 5100 with OME 884 w/trim pack, 17" fuel trophy wheels wrapped with 32" toyot open country m/t, bakflip fibermax tonneau cover, Avec 30" led light bar behind lower grille, marathon seat covers in max 5 camo pattern, trimmed front and rear mud flaps, more to come.
    Here is my setup now. Like I said I know enough to get by but couldn't figure out a way to get the switch to cut off with the truck because having the power coming from the blue sea it provides power all the time to the switch but with your guys help I have an add a fuse on the way so I can connect the power how I warn it to be(switch only having power when the ignition is on). Just going to take the blue wire from the relay and run it to the ass a fuse so it should take care of my so called problem. It doesn't draw that much anyways but don't like having the power on all the time. I tested the draw and it wasn't enough to have created my bad battery that I originally had but I now have an optima yellow top. I don't have the skills like you guys have with building your own relay system but I am learning. It's amazing the toll a bad battery effects the performance of your truck. After installing the new batter it does feel like it has netter power and throttle response. Luckily I work in a CE unit and had someone help me make the holder and them I color matched it. The only other thing I have connected to the box right now is my hood LEDs that the ground is connected to a pin switch so it cuts off when the hood is shut. When I do plan on adding more light bars I will just have to put in another AAF right so the switch power will cut off right? How many of those can you ass before it gets to be RO much and ha e to go another route? Po ce again thanks for the help and giving me a problem solver fellas!!almost every light on my truck is led now except for the third break lights. Any suggestions on what kit to use on adding led bed lights?
  4. Nov 26, 2015 at 1:01 AM
    Dirtboyz
    Spanaway, WA
    DCSB trd sport 4x4
    Hope all of you a good thanks giving!! And as gain thanks for the help.
  5. Feb 3, 2020 at 3:50 PM
    Ginger-Vitis
    Ginger-Vitis Well-Known Member
    08 Tacoma 5spd
    So if I have an external fuse box with five sets of lights and a compressor on it can I hook it up to a piggyback fuse for ignition power? And if so how many volts should that fuse be?
