Is it true that Entune system does not allow for aftermarket speakers?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by javi191919, Jan 21, 2017.
  1. Jan 21, 2017 at 6:49 PM
    DarkSky
    DarkSky Well-Known Member
    Oregon
    2016 SR5 Double Cab V6 Auto 4X4 Barcelona Red
    Not wanting to replace the headunit and and lose ability to configure vehicle settings, and not wanting to put a lot of money into an amp and sub-woofer (been there done that enough times over the years in previous vehicles), I simply upgraded the front speakers with Pioneer 3-ways. Contrary to what some others say, it definitely improved the sound. As good as a separate amp system? No... but much better than the factory speakers. Those factory speakers are a joke. Must have cost Toyota about 12cents each.
    shakerhood likes this.
  2. Jan 21, 2017 at 7:12 PM
    Optimaltaco
    Optimaltaco Well-Known Member
    Dave
    Cochrane, AB
    '17 Tacoma DCSB TRD Off-Road
    TRD Pro - Grill and Rear Tail-Lights OEM Roof Rack FN overland 17x8.5” -6 BFG KO2 Morimoto 2 stroke LED headlights 30” auxbeam light bar Custom built Canopy Readylift 3" spacer kit Deaver 1.5-2" AAL Amber hazard strobe lighting
    Thee idatalink maestro should still allow for full OEM configuration with the 16+ tacomas if installed in a proper pioneer/alpine/kenwood doubledin radio.
  3. Jan 21, 2017 at 7:20 PM
    Optimaltaco
    Dave
    Cochrane, AB
    I used to be a car audio / remote starter installed before my current job, when we had a guy with a 16' sport show up, we did a full Hertz energy speaker up-grade. (6.5" comp in the front and 6.5 coax rear) built custom mounting brackets for all the speakers. Couple weeks later he came back and we installed an Audison BitTen processor, to better tune the speakers and allow the proper frequencies to go to them etc etc etc. Wasn't cheap but was well worth for him, he didn't want a sub for various reason that escape me now. But as per OP's question, 99.99% of cars can have the speakers replaced no problem just depends how much it will cost lol, sometimes it's more complete then just replacing the speakers due to there maybe having capacitors built in or ohm ratings (*cough* GM Bose systems) or sometimes it's just wired to a factory amplifier, there are a lot of variables that can go into that. But the Tacoma speakers are 100% changeable no matter what.
    Jaggerbub and gpb like this.
  4. Jan 21, 2017 at 7:38 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    The responses will likely be worse in the audio section. Replacing stock speakers without a replacement headunit or dsp and amp to correct the power/eq coming out of the stock headunit is akin to getting a spacer lift. Little to no improvement and in some cases/aspects it can turn out worse than it was to begin with.
    To OP, if you insist on going down this route get speakers that do not require much power. Id be surprised if the stock headunit sends more than 25w to each speaker
    Optimaltaco likes this.
  5. Jan 21, 2017 at 7:42 PM
    Optimaltaco
    Dave
    Cochrane, AB
    Yea that's why the customer came back to get the audison BitTen from us. The hertz speakers are great but the difference wasn't all that apparent. There have been times where aftermarket speakers sounded worse due to the lack of frequency response they have compared to factory speakers.
  6. Jan 21, 2017 at 7:47 PM
    Ginotjr
    Ginotjr Well-Known Member
    2016 Black Tacoma TRD Sport
    Any speaker you use to replace the factory ones will an upgrade, cheapest looking speakers I've seen.
  7. Jan 21, 2017 at 8:28 PM
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    I ended up with the JBL Entune speaker system. Originally I wasn't going for this and was already planning out my audio system when I got my truck. I got a great deal on the truck with JBL otherwise I wouldn't of gotten it. Its not blow your doors off but it does get loud enough for me. No distortion and just good clean sound. I was surprised.
    AANorthwest likes this.
  8. Jan 21, 2017 at 8:29 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    jimbro, Hammer40 and Ginotjr like this.
  9. Jan 21, 2017 at 10:57 PM
    fergsonfire
    fergsonfire Electrical Guru
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    Do not go back to that car audio shop. All they were doing was trying to get more money out of you. Yes you can swap out speakers on a tacoma however you will need adapter rings, but any normal car audio speaker will work as tacomas don't have weird systems like euro cars. Second, if you are going to do this you should get an amp for your speakers. The stock head unit output is not very good and will not drive aftermarket speakers very well. Third, should this not be a big enough change the next step would be to add a subwoofer that is either powered by the amp you already purchased and installed or powered by a secondary amp dedicated to the subwoofer. This will improve the bass response of the system as most 6.5" speakers will not go into the sub bass range. Finally if that if the sound is still not enough I would recommend an audio processor along the lines of a rockford 3sixty.3, audison bit ten, arc ps8, etc. This is not a required step unless you are looking for more and will cost money for the unit plus time to tune, which is arguably longer and more expensive than installing by a long shot. Do not buy from taco tunes, their products are poorly made. If you have any questions on audio stuff please don't hesitate to ask. I run hybrid audio legatia 6's with legatia L1pro tweeters, jl 900/5, a morel ultimo sc 10, and a rockford 3sixty.3 off a factory deck, although not yet installed on my new '17 waiting for a box from Marv. On my 13 it was amazing and I fully expect the same from my '17. I have installed for years and am full of electrical/audio knowledge. So please realize no question is too dumb and ask away.
    GPsevinSixx and gpb like this.
  10. Jan 21, 2017 at 11:53 PM
    Hammer40
    Hammer40 Well-Known Member
    SW Washington
    '96 Tacoma (sold). '05 DCSB TRDOR(sold) '17 DCLB TRDOR (Traded)
    tonneau cover.
    http://oemaudioplus.com/toyota/tcd1600/
    Give that a gander
    Jaggerbub likes this.
  11. Jan 22, 2017 at 1:18 AM
    sqa4life
    sqa4life Well-Known Member
    2017 SR5 4x4 DCLB MGM
    I upgraded the speakers accordingly to crutchfield recommendation and ended up the stock speakers back. Enough said.
  12. Jan 22, 2017 at 5:11 AM
    Doggman
    Alabama
    2017 TRD OR MT
  13. Jan 22, 2017 at 6:55 AM
    Pportera
    Pportera Well-Known Member
    3rd gen.
    The entune signal output is filtered and de- tuned for the stock crappy speakers. Aftermarket speakers will not shine there best with this input. Best to upgrade head unit and speakers.
  14. Jan 22, 2017 at 10:00 AM
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    That looks like something I'd look into. Liking all the plug and play features, and I like the factory look of it.
  15. Jan 22, 2017 at 10:59 AM
    #35
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
    This is not true.... You do not need to upgrade the stock head unit.
  16. Jan 22, 2017 at 11:16 AM
    #36
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Is there a way to run a 4 channel amp, speakers, and get that full performance of the aftermarket speakers, and maintaining steering wheel/equalizer settings on the HU?
  17. Jan 22, 2017 at 11:17 AM
    #37
    fergsonfire
    Kyle
    Portland, OR
    17 DCSB TRD OR BBP
  18. Jan 22, 2017 at 11:25 AM
    #38
    hookembevo
    hookembevo Well-Known Member
    Austin, TX
    2016 Tacoma DCSB with 6MT
    Snugtop Rebel with some options Body Armor Rock Steps Rhino Mats Weathertech Mudflaps Radar detector hardwired to rear view mirror. Stereo upgrade: Amp: Arc Audio XDI805 LOC: AudioConnect LC7i Front Speakers: Hybrid Audio Technologies Claris 6.5 Rear Speakers: Hybrid Audio Technologies Mirus 5.25 Sub: Pioneer TS-SW2502S4 Box: Pioneer Ud-SW250T Bilstein 5100s OME 885 Springs Single Add-A-Leaf BFG KO2 265/75/16
    You can absolutely replace factory speakers with something better. It may or may not sound better without adding some power. Plenty of posts of users' systems in the Audio section.
  19. Jan 22, 2017 at 11:27 AM
    #39
    Aw9d
    Aw9d That one guy
    I love hearing the bullshit stereo shops tell people.
    fergsonfire likes this.
  20. Jan 22, 2017 at 11:31 AM
    #40
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Obviously, but some people on TW stated that running a "secondary amp" other than the HU, you lose some funtionality.
