IS MY 2013 TACOMA PRE-WIRED FOR A BACKUP CAMERA?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by likefreddyvm, Oct 2, 2024.
  1. Oct 2, 2024 at 5:12 PM
    likefreddyvm
    likefreddyvm [OP] New Member
    Jose
    2013 Toyota Tacoma
    Hi everyone,
    I recently purchased a 2013 Toyota Tacoma and I'm considering adding a backup camera. I’ve heard that some models may come pre-wired for this feature. Can anyone provide insight on how to check if my truck is pre-wired for a backup camera?
    • Body Type: Double Cab Pickup
    • Engine: 2.7L (2700 cc), 4-Cylinder, 159 HP
    • Drive Type: 4x2
    • Trim: Deluxe
    • Mode: Pre-Runner
  2. Oct 2, 2024 at 7:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Pull the cover from the tailgate and look inside to see if you have the electrical cable inside...
    Or if you can see the bottom of the tailgate the wire loom for the camera enters the bottom of the tailgate on the passenger side (right side)
    TnShooter likes this.
  3. Oct 3, 2024 at 8:58 AM
    winkeldc
    winkeldc Well-Known Member
    2014 Reg Cab 4x4
    But also check to make sure you have four wires going to the cab of the truck at the harness connection going to the tail gate under the bumper that Jimmyh mentioned. Some just have two wires going to the cab, and that isn't just a plug n play. Here are a couple threads.
    https://www.tacomaworld.com/threads/2013-plug-n-play-back-up-camera.607382/#post-20511049
    https://www.tacomaworld.com/threads...out-backup-camera-option.327638/#post-8758467.
