Is my alignment ok?
Discussion in 'Suspension' started by TacoSupreem, May 7, 2010.
  1. May 7, 2010 at 7:37 PM
    ab1984
    ab1984 Member
    sylmar ca
    06 prerunner, access cab, TRD off road,silver
    3" spacer lift, 32" BFG all-terrains, homemade ram-air intake, DTR lights mod,blacked out billet grille, black westin bullbar, debadged, color matched grill surround, pro comp 7089's
    i had the same problem with the squeeking after my alignment. it turned out to be the sway bar rubbing the strut at the bottom of the coil..
  2. May 7, 2010 at 7:46 PM
    TacoSupreem
    TacoSupreem [OP] Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    ^^Thanks man imma go check that!
  3. May 7, 2010 at 7:53 PM
    TacoSupreem
    Hayden
    Kentucky
    Sounds like its only on the driver side front? It squeaks just from me getting in and out of the truck?
  4. May 8, 2010 at 1:48 PM
    ab1984
    ab1984 Member
    sylmar ca
    yup. just like mine. only on the driver side. it bugged the crap out of me!! i put a spacer between the sway bar bracket and the frame and the sqeakin went away..
  5. May 8, 2010 at 7:02 PM
    TacoSupreem
    Hayden
    Kentucky
    Is my rear alignment ok?
  6. May 8, 2010 at 7:05 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    That thrust angle is a little high- but it's kind of a pain in the ass to adjust unless you have an alignment rack you can get on and work on your rig on. And I don't think it'll do any major damage if you don't work it out.
  7. May 8, 2010 at 7:21 PM
    TacoSupreem
    Hayden
    Kentucky
    ok thanks, i didnt know if that would make my tires wear unevenly?
  8. May 12, 2010 at 6:22 PM
    TacoSupreem
    Hayden
    Kentucky
    Ok guys im going back in the shop for another alignment on friday. So should i ask them to set my camber at 0 and hopefully that'll bring my caster up to 2.3 range?
  9. May 14, 2010 at 9:23 AM
    TacoSupreem
    Hayden
    Kentucky
    Ok truck is in the shop now for another alignment. I told the tech to set it at 0 camber and toe and 2.3-2.4 caster. Hopefully that makes it handle a little better? I'll post my new alignment sheet in a bit.
  10. May 14, 2010 at 2:17 PM
    TacoSupreem
    Hayden
    Kentucky
    Well i just got my truck back. They didn't do anything to it! They said they got too busy!:mad: They want me to bring it back on monday and leave it for 2 days! :eek:
