Is my clutch going out? Or something else?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Murph, Jun 14, 2013.
  1. Jun 19, 2013 at 10:56 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I'm running the URD stage 3 clutch and love it. I killed my clutch at about 220K miles and only because I installed the supercharger and the old factory clutch couldn't handle the extra power.
  2. Jun 19, 2013 at 10:57 AM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I helped a friend replace a clutch on an earlier toyota truck a couple years ago. I recall a good swivel joint adaptor was critical to getting to a few hard to reach bell housing bolts. Not too bad a job. We did bust the cheapo 3/8" swivel joint and had to run for a 1/2". An assortment of extensions are also important.
  3. Jun 20, 2013 at 7:45 PM
    Murph
    Murph [OP] Go Pack Go!
    Tyler
    Fox Valley, WI
    2000 Extra Cab TRD O/R
    3" lift. American racing 15'' rims. 33x12.50 BFG A/T tires. tool box. ARB bumper, mile marker winch, kc highlights. No carpet inside sprayed with bed liner. Kicker door speakers. Alpine head unit.
    I need a super charger :burnrubber: or an old turbo charged 22RE :p.
  4. Jun 20, 2013 at 7:46 PM
    Murph
    Tyler
    Fox Valley, WI
    Thanks for the heads up, I like working on my own stuff... perfect excuse to buy more tools :crapstorm: :p
  5. Jun 22, 2013 at 8:35 PM
    Murph
    Tyler
    Fox Valley, WI
    Install went flawlessly, it only took a couple hours with some breaks in between. The yota lives to fight another day!!!
  6. Jun 23, 2013 at 5:19 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    glad you got it fixed!
  7. Jun 23, 2013 at 7:58 PM
    Murph
    Tyler
    Fox Valley, WI
    me too its insane how quickly the clutch engages now. brings into prospective how bad the old was. A few tips for install you will definitely need a 3/8 swivel and about 2 feet of extension's to remove top bell housing bolts (17mm). I also borrowed a blind finger bearing puller for the pilot bearing. And the drive shaft bolts are a pain in the ass since there splines. A little side note dont forget dot 3 brake fluid for the reservoir. Final though a 10mm flare nut wrench for removal from master cylinder.
