Is my fog light switch supposed to light up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShaLor, Jan 7, 2012.
  1. Jan 7, 2012 at 9:29 PM
    ShaLor
    ShaLor [OP] Well-Known Member
    Shane
    Burbank, CA
    07 4x4 Doublecab TRD Off Road
    Custom mud flap removal from rock on trail :), Tailgate Hose Clamp Mod, Cobra 75 wx st CB install, 19 more D-Rings in the bed, Satoshi Grill, Fog Lamp on any time mod. Relentless Fab CB antenna hood mount, LED bed lights, Demello Hybrid Sliders, Undercover Tonneau Cover, Lighted 4x4 switch
    It seems strange to me that my fog light switch doesn't light up. Is this normal or is mine defective?
    The Rear differential switch lights up at night, but the fog light switch doesn't. I am aware that it has no indicator as to whether to fog lights are on or not, but it seems weird that toyota would make it hard to find in the dark. I suppose they did the same thing for the 4x4 switch.
    For those that don't want to read the entire post, yes it is supposed to light up. The part number for the bulb is: 90011-01058 thanks to billyjoe
  2. Jan 7, 2012 at 9:32 PM
    Jholder70
    Jholder70 Well-Known Member
    Iowa
    2012 TRD Sport V6 Silver
    Still trying to decide...
  3. Jan 7, 2012 at 9:34 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    my 05 lights up
  4. Jan 7, 2012 at 9:34 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    statement retracted.....
  5. Jan 7, 2012 at 9:34 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Fog light switch and diff lock are supposed to light up. There is a small light bulb in the switch that costs about 6 bucks at the dealer.
  6. Jan 7, 2012 at 9:34 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Mine is backlit , just the same as your diff lock button in your pic
  7. Jan 7, 2012 at 9:35 PM
    apotter
    apotter Well-Known Member
    Southern Maine
    '13 TRD Sport
    Retrofits, Aux bed lighting, Map light mod
    It should light up...at least mine does when it's not being tempermental. Somtimes it takes a solid flick but it will come back on. I've taken the entire switch apart and check for power and continuity...all checks worked. There's no reason for it to not light up, it must just be a mild defect.
  8. Jan 7, 2012 at 9:35 PM
    weazle
    weazle Well-Known Member
    Wesley
    Huntsville, Tx
    Billet grill, CAI, debadged, hella fogs, custom bumper guard, trd skid, trd sport bed decals(not stock), bilstien 2.5" lift, aal, halos, interior neons, lots of random paint.
    those wheels look sick. and my 09' fog light switch does not.
  9. Jan 7, 2012 at 9:35 PM
    OZ-T
    Peter North
    British Columbia
    No
    No
    Yes
  10. Jan 7, 2012 at 9:36 PM
    Detective_Dan
    Colorado Springs
    thats weird....my 2010 dcsb and my 2011 XRunner do not light up...both brand new when i bought them
  11. Jan 7, 2012 at 9:39 PM
    billyjoe
    billyjoe Taco Fever - I've got it bad!
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    Extang Trifecta Tonneau
  12. Jan 7, 2012 at 9:40 PM
    Detective_Dan
    Colorado Springs
    you could also just look if the switch is pressed in...
  13. Jan 7, 2012 at 9:40 PM
    ShaLor
    Shane
    Burbank, CA
    OK, anyone know how to get the switch out of the dash? I tore up my hand pretty good trying to reach behind through what I call the coin tray. I saw someone say they popped out the blank beside it, but since I have a rear diff lock button there that is a no go.
  14. Jan 7, 2012 at 9:42 PM
    apotter
    Southern Maine
    '13 TRD Sport
    The light came through stock on the '09...I'm assuming it's stock on all of the switches? give it a good flick a few times and see if it makes a difference...it did on mine anyway, and oddly better than taking it apart and trying to adjust it to work properly everytime. Make me wonder why they charge almost $60 for the thing.
  15. Jan 7, 2012 at 9:43 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    you can take it apart to get to it. You have to take out the foot piece right next to the drivers side door, then then black block, then the kick panel, then the lower dash.
  16. Jan 7, 2012 at 9:44 PM
    ShaLor
    Shane
    Burbank, CA
    Wow :eek:
  17. Jan 7, 2012 at 9:45 PM
    apotter
    Southern Maine
    '13 TRD Sport
    No joke...it's a B*%@( to get to.
  18. Jan 7, 2012 at 9:46 PM
    billyjoe
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    Maybe if you're a cat...:rolleyes:
  19. Jan 7, 2012 at 9:49 PM
    ShaLor
    Shane
    Burbank, CA
    :rofl:
  20. Jan 7, 2012 at 10:06 PM
    billyjoe
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    The part # for the bulb is 90011-01058. I know this because I had to replace mine when I bought my used '05 in late '09. Didn't dissassemble anything other than just popping out the surrounding blanks &, I believe, the Side-Mirror "Switch" as well (hey, it was 2 years ago). All you need to do is press behind it to pop it out. Hope that helps...:)
