Is my frame buckled?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anamorphic, Apr 11, 2013.
  1. Apr 11, 2013 at 7:05 AM
    anamorphic
    anamorphic [OP] Well-Known Member
    08 TRD Sport 4x4
    May have found the reason the rear in the truck can't be aligned.
    This is on both sides. Is that normal?
    295F8F2B-5282-4A89-98AF-A5C8710533A9-435_4afd0ae40eb99df61a333a3f3b78cf106f67c95a.jpg
    14FEF8B8-4B5E-429D-AF60-006394C7CB81-435_dd5bf692dc55dde5540fc9991659f60d8d6c5321.jpg
  2. Apr 11, 2013 at 7:07 AM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    Can't properly tell what that is
    I suggest add a few more pics from more angles
    Is it a scrape?
    You can't really align the rear as that is what this looks like
    What's the story on this?
  3. Apr 11, 2013 at 7:30 AM
    anamorphic
    08 TRD Sport 4x4
  4. Apr 11, 2013 at 8:43 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Just looked at mine on my lunch break...looks almost the same on both sides, maybe a little less wrinkled but same never the less and I have no issues.
  5. Apr 11, 2013 at 8:51 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    so we are aligning rear ends now?
    last I checked the front mount of the leafs are bolted via a mount to the frame while the diff is located by 4 threaded ends from shackle U-bolts, kinda pinned. Only thing I can see being done is loosing the U-bolts and attempting to bump a few , and it would not be much.
    typically the alignment shops don't align the rear of a truck.
  6. Apr 11, 2013 at 8:52 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Theres no aligning the rear in the truck. Does it dog track? You having a problem?
    Frame looks normal.
  7. Apr 11, 2013 at 9:41 AM
    anamorphic
    08 TRD Sport 4x4
    I've got to hold the wheel slightly to left to drive strait on the highway. Center lane. No road crowning. So, to answer- yes. The truck dog tracks to the right. The wheelbase is 1.4 inches different from right side left.
    See alignment spec sheet.
    Had the truck on a lift last night. Centering pin isn't sheered off. Nothing wrong with the leafs.
    2FE8D09C-583C-4B55-BB99-731562ECD90E-202_627b20d06142718a51742b0c844fa20697a36b00.jpg
  8. Apr 11, 2013 at 9:41 AM
    anamorphic
    08 TRD Sport 4x4
    Thanks for that!!
  9. Apr 11, 2013 at 9:47 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I'll get an alignment check here soon and post it. Mine drives straight enough. The front Pass. Cam bolts are froze up solid and the tie rod took a gorilla to turn.
    My old alignment numbers, the rear is close to yours and I had to hold the steering wheel to the left a litte to go straight but the new Front alignment changed that.
  10. Apr 11, 2013 at 9:59 AM
    anamorphic
    08 TRD Sport 4x4
    I guess there could be some compensation in the front to make the truck track strait, but that by no means would explain or fix this:
    Front wheel well L&R side:
    1E935339-2246-48E2-AC44-BCAF78A29618-202_aec3ef08302189804f300172d51ad797b816d7b6.jpg
    32FA8A87-D627-40B1-B9CD-BED0443210F3-202_9d3f55b877ce7957e1b01f9b0bc69a88deb74a12.jpg
  11. Apr 11, 2013 at 10:04 AM
    rleete
    rleete Grumpy old man - get off my lawn
    Roger
    Rochester, NY
    Base DC, SR5, TRD Sport
    Billet grill
    Bed to frame alignment would account for that much.
  12. Apr 11, 2013 at 10:08 AM
    anamorphic
    08 TRD Sport 4x4
    Would I need to take it to a body shop for that?
  13. Apr 11, 2013 at 11:14 AM
    rleete
    Roger
    Rochester, NY
    Billet grill
    Not unless you're helpless. Loosen bolts, knock bed around, tighten bolts.
  14. Apr 11, 2013 at 11:19 AM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Measure from the front spring eye to the spring pad on the axle, both sides should be the same. If theres a difference your axle could have shifted on the springs, its been said many times on TW that the factory uses low torque settings on the u-bolts.
    And finally if the axle shifted and sheared the center pin you won't see that until you remove the u-bolts.
  15. Apr 11, 2013 at 11:22 AM
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    What does the gap on each side of the bed look like?
    Cab to bed gap?
  16. Apr 11, 2013 at 11:26 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Depending where the OP lives (i.e. how much salt they put on the roads), after five years, the bed bolts could be in there pretty good. I see reports of people stripping the torx pattern from the bolt head when installing extra D-rings.
  17. Apr 11, 2013 at 11:32 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    truth
    this
    this
