Is my head gasket blown?
Discussion in '1st Gen. Tacomas (1995-2004)' started by moustache ride, Jan 6, 2012.
  1. Jan 6, 2012 at 10:06 AM
    moustache ride
    moustache ride [OP] Member
    Golden, BC
    tacoma
    6" fabtech, 8000lb Warn W/ARB bumper, command start, 33 pro comps on 15s, Apline stereo.
    I've got a 97 3.4. It's loosing coolant and it seems to be getting worse. I've added almost 7 liters in the last 3 months.
    I can smell coolant in the cab while driving so I suspected a bad heater core, but the floorboards are bone dry. Theres no visible leaks. oil looks fine.
    I pulled the codes and its not missing (only code was intake air temp circuit). It dose idle rough on start up for a few seconds then its fine, and some white smoke as well.
    Any input would be greatly appreciated.
  2. Jan 6, 2012 at 10:08 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    When's the last time the water pump and timing belt were replaced?
  3. Jan 6, 2012 at 10:11 AM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    :pray:Sub'd, think I may be in the same boat.
  4. Jan 6, 2012 at 10:13 AM
    moustache ride
    Golden, BC
    tacoma
    I only bought the truck a year ago and the guy said it had been done not too long ago but I'm not entirely sure. Is there a way that I can check it?
  5. Jan 6, 2012 at 10:20 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Check to see where the coolant is leaking from. If it is dripping near and under your alternator then its your water pump. Most common symptons of coolant leaking is your water pump.
    Nice truck btw! And welcome to TW from here in Nelson BC!
  6. Jan 6, 2012 at 10:25 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    ^^this. My bet is the water pump is leaking, very common problem.
  7. Jan 6, 2012 at 10:28 AM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Yes, mostly likely you'll find that the frame that goes under the engine will have a wet spot on the right if your looking from the front.
  8. Jan 6, 2012 at 10:50 AM
    moustache ride
    Golden, BC
    tacoma
    theres no visible leakage or wet spots anywhere near the water pump and after the truck sits for a while theres no coolant dripping anywhere under what so ever.
  9. Jan 6, 2012 at 10:52 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    ok is it white smoke you're seeing or is it just the normal condensation that is always there on cold days?
  10. Jan 6, 2012 at 10:52 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    If you had a blown HG coolant in the oil would be pretty obvious, and you would be getting some degree of white smoke out of the exhaust.
  11. Jan 6, 2012 at 12:42 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    You would also get exhaust bubbles in your coolant rez
  12. Jan 6, 2012 at 1:36 PM
    moustache ride
    Golden, BC
    tacoma
    OK so I just went out and started it up and it looks more like white smoke to me. it lingers in the air for a bit instead of dissipating right away like steam, and I managed to make a pretty big cloud from revving the engine. I hit the throttle a bunch of times while watching the coolant in the top of the rad and managed to squirt coolant right out of the rad. Would this happen normally or would that only be caused by pressure build up in the system from the compression in the cylinder backing up though the failed gasket? At this point I'm thinking I'll have to just take it to a shop.
    Also I would have to wait for the funds to be able to pay for a HG job. Is there anything bad about putting in some stop-leak or some sort of product to buy me some time while I build up the funds?
  13. Jan 6, 2012 at 1:40 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Stop leak--NOT GOOD. Still think it is water pump or hose. Course BLACK PEPPER will stop minor leaks and has NO chemicals that will do damage.
    Old trick-CHEAP and it works.
  14. Jan 6, 2012 at 1:45 PM
    newertoy
    Kevin
    East Tn
    2003 4x4 extra cab
    While reving the engine--the water pump is pumping more fluid-pump is on the cam.
    That is normal. Any leakes under the truck??? After parking overnight?
  15. Jan 6, 2012 at 1:56 PM
    moustache ride
    Golden, BC
    tacoma
    no leaks under. Theres snow on the ground here so it would be easily noticeable if there was.
  16. Jan 6, 2012 at 1:58 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    If you got it to shoot coolant out I think it is probably blown. A shop could tell you for sure though.
  17. Jan 6, 2012 at 1:59 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
  18. Jan 6, 2012 at 2:08 PM
    moustache ride
    Golden, BC
    tacoma
    Thats what it looks like.
  19. Jan 6, 2012 at 2:09 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    How many miles are on it and has it ever been overheated?
  20. Jan 6, 2012 at 2:24 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    I overheated my engine but luckily it didnt blow the head gasket
