Is my head gasket blown?
Discussion in '1st Gen. Tacomas (1995-2004)' started by moustache ride, Jan 6, 2012.
  1. Jan 6, 2012 at 2:25 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    It is so easy to blow it on these trucks because the heads are aluminum but the block is iron.
  2. Jan 6, 2012 at 2:30 PM
    moustache ride
    moustache ride [OP] Member
    Golden, BC
    tacoma
    6" fabtech, 8000lb Warn W/ARB bumper, command start, 33 pro comps on 15s, Apline stereo.
    It's got 125k miles. And it hasn't over heated at all.
  3. Jan 6, 2012 at 2:32 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Yeah, Fuck Ill drop my other engine in before i re-do the HG
  4. Jan 6, 2012 at 2:34 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    strange, if it does end up being the HG, make sure they check if the heads are warped.
  5. Jan 6, 2012 at 3:34 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Its your HG or heads then... I just replaced my whole engine cause it had 200k in it ... so might as well.
  6. Jan 6, 2012 at 5:08 PM
    moustache ride
    Golden, BC
    tacoma
    I went and talked to a mechanic and he was unsure but doesn't think it's the head. Shes going in on monday for a pressure test so hopefully I'll find out then.
    Thanks for everyones help.
  7. Jan 6, 2012 at 8:48 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Thats the thing to do, let us know how it goes.
    FYI its actually called a leak down test;)
  8. Jan 10, 2012 at 8:56 PM
    moustache ride
    Golden, BC
    tacoma
    Just got the verdict. Gasket is toast. I havent had a chance to talk to the mechanic as I'm working out of town, but he quoted $2450 to do it. Seemed a little steep to me, but looks like I might be looking into getting a whole engine after all any sugestions on how/where to find a decent one?
  9. Jan 10, 2012 at 9:15 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    That sucks man.
    It shouldnt be too hard to find a 5vz-fe around BC. I have a spare one but im not willing to part with it now. I would check all the local scrap yards for the recalled Tacomas. Maybe even call your Toyota dealership and ask where they send the recalled Tacomas or where you might find one.
    Im sure you could also find one in the states but it might be a hassle to get it across the line. Good luck!
  10. Jan 10, 2012 at 9:42 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Talk about getting raped with no lube!
    that is way steep.
    It's really not that much work unless the head is warped which it likely is. I would call around.
  11. Jan 10, 2012 at 10:21 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Probly not worth tearing apart if theres chance the heads were warped which they likely are
  12. Jan 10, 2012 at 10:23 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    pretty sure you can just get the heads resurfaced by a machine shop.
  13. Jan 10, 2012 at 10:26 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    Wayyy to much... i got quoted 500 for everything .... and a new engine is bou 700-1200.
  14. Jan 11, 2012 at 1:24 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Tell your "mechanic" he's out of his fuckin' mind, it wouldn't cost that much even with 2 new heads & yeah if i spent that much , i'd throw another $500 at it & get a completely rebuilt engine...:eek::eek:
  15. Jan 11, 2012 at 7:27 AM
    #35
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Just a heads up:
    Check for coolant leaks with a coolant system pressure tester: Checking for bad valves, rings, or gaskets can be done with this tool and an air compressor:
    It is more comprehensive than a compression test. It will tell you not only the health of the engine, but also where a problem is.
    Bubbles of air coming out in the radiator=bad gasket/cracked coolant passage. Excessive air coming from PCV line=bad rings. Air coming from intake=bad intake valve. Air from exhaust=bad exhaust valve.
    A coolant pressure test will tell you for sure you have a leak, but you'll have to hunt for it. The proof you have an engine problem comes from a leak down test.
  16. Jan 11, 2012 at 10:52 AM
    #36
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    unless you're trucks doing this, it's most likely a leak. They can be very hard to find sometimes. Take it to a shop that does a free pressure test and go from there.
  17. Jan 11, 2012 at 11:07 AM
    #37
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    I would use a set up that determines if you have exhaust gases in the cooling system. It takes about a minute to see and most shops have them around. It's a chemical that when you pull air from the radiator thru the chemical, will change color when exhaust is present. very cheap. Nothing to do with pressure test, or leak down as those things have "other" causes as well.
    If the heads are warped they can just be planed. I would search for a used motor before doing a HG job at that price.
  18. Feb 14, 2015 at 11:34 AM
    #38
    scootn2nature
    scootn2nature ttora member since 2001
    orinda
    2000 2.7l sr5
    bentup sliders, tjm t17, badland rear,custom leafsprings, fabtech performance co's,
    this not always true you can have oil in water, water in oil, exhaust bubbles in water, water out the tailpipe, one of these, all, or a combination
  19. Feb 17, 2015 at 6:46 PM
    #39
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Yep. I have ~110psi on 5 cylinders and ~90psi on cyl 3 on my engine. No leaking anywhere and had some white smoke from the exhaust after the truck sat for a few weeks between running.
    I used Bar's Leak 1111 and that seemed to fix the leak as I haven't seen any white smoke or have any measurable coolant loss in 6+ months. It's worth the $20 investment to try to see if that solves your problem.
    I assume my problem was a small head gasket leak between the COOLANT and cylinder 3 part of the gasket and nothing else, since my oil is fine, the radiator pressure test is fine and so on...
