Is my throw out bearing bad from the start?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco me elmo, Sep 20, 2010.
  1. Sep 20, 2010 at 7:32 PM
    Taco me elmo
    Taco me elmo [OP] Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Around January I had Speed Freak install a URD comp stage 2 clutch kit for the 5VZ 4wd. and since they dont sell Flywheels. A LCE 38 lbs Flywheel.
    The reason for the upgrade was I had a bad sounding whir and what sounded like worn bearings sound unless the clutch was pressed in.
    Once we completed the job my truck was making a similar noise unless the clutch was pressed... only this time it was like a super charger whine that continues to get louder as I accelerate.
    It has been 9 months and I have had serious issues with this setup..
    The first 2,000 miles were ugly and smelled of clutch all over the place and the sound never got quieter, No I was not romping on it either.
    I would love to buy a new throw out bearing and have it be fixed .. but its a full day to exchange such a small part..
    Again the sound goes away once the clutch is pressed in, And since day one has it been this way.
    Once the clutch broke in it grabs well but the sound is driving me insane!!!!!
  2. Sep 20, 2010 at 7:38 PM
    HondaGM
    HondaGM CallSign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    sounds like you have a bad input shaft bearing,i would think the tob would make more noise when the pedal was depressed.
  3. Sep 20, 2010 at 7:45 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Is that replaceable by pulling the trans back and inspecting the clutch?
  4. Sep 20, 2010 at 7:47 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    uh,i dont think so..you will need to go into the trans.
  5. Sep 20, 2010 at 7:48 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    That is bad news....
  6. Sep 20, 2010 at 7:51 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    well,it depends.its not gonna cost much for the part,but if you cant do it yourself it will be alot of labor charges.if it was me, i would replace all the shaft bearings while i was in there.
  7. Sep 20, 2010 at 7:52 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Yeah its like a $40 part... but finding someone to do it is gonna suck ><
  8. Sep 20, 2010 at 7:59 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    if you can pull the trans out, you will save yourself alot of money.then take it and let them put the bearings in,and you put it back in.a big chunk of the labor is gonna be from pulling the trans.
  9. Sep 20, 2010 at 8:01 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    K sounds good, I will buy the part and save a weekend to do the project.
  10. Sep 20, 2010 at 8:05 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    good luck:D
  11. Sep 20, 2010 at 8:07 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    mine makes the exact same noise.....im in need of a new clutch so i might check it out while im in there but it really dont bother me to much
  12. Sep 20, 2010 at 8:10 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I believe we are on the right track here, hey Micah is that "Turbo whine" you speak of in all gears or just certain ones ??
  13. Sep 20, 2010 at 8:14 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    Mainly just first gear and idle really bad.. once i start to get up in gears you don't hear it anymore.
  14. Sep 20, 2010 at 8:29 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Yep I agree with HondaGM, it may not be completely toast yet, but its time is very limited.
    & he mentioned taking it out (the trans.) yourself to save some $$
    Also a good call but you will want a reputable shop to do the bearing replacement because that shaft runs the entire length of the trans & its in the center surrounded by other,shorter shafts with gear clusters if I'm not mistaken, a scary environment to be in if you've never messed with a manual trans...:eek::eek::eek:
  15. Sep 21, 2010 at 5:49 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    Good luck man. I'm about to do my clutch and release bearing this weekend.
  16. Sep 21, 2010 at 11:14 AM
    davestaco
    David
    Schofield Barracks
    i dont ever mess with transmissions.....it is way to easy to screw the pooch......my noise goes away after the truck warms up though?
  17. Sep 21, 2010 at 11:49 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Well yours maybe another issue, once that input bearing makes its presence known (making noise) it usually doesn't go away, but it sometimes will do it in different gears i.e'; no noise in 1st but sounds like its going to grenade in 3rd...:eek::eek:
  18. Sep 21, 2010 at 12:49 PM
    davestaco
    David
    Schofield Barracks
    oh...thanks for the info...im gonna get my bro to check it out...he is also my mech.
  19. Sep 22, 2010 at 4:52 PM
    Taco me elmo
    Tophat bobcat
    Slow polished TuRD
    Anti theft 5-Speed
    I have Speed freak, AKA Jason to do the work for me. He said he will tackle it head on for me.
    I just need to set up a date and buy the parts. :)
    Going to replace all 3 just in case,
    Throw out bearing, Pilot bearing and input shaft bearing.
    I am very aggressive to my truck.. high revs and hard shifts are a norm for getting on the freeway for me.
  20. Sep 22, 2010 at 7:34 PM
    davestaco
    David
    Schofield Barracks
    when i get my new clutch i will also do these 3
