is something broken?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nb_tacoma, Feb 17, 2011.
  1. Feb 17, 2011 at 4:31 PM
    nb_tacoma
    nb_tacoma [OP] Well-Known Member
    nick
    Thunder Bay, ON
    2006 SR5 access cab 4x4
    2.5 inch toytec lift /w rear block 255/85/16 cooper discoverer st's Westin light bar with 2 hella 500's Satoshi grille mod BHLM bumper valence painted with rocker guard relocated the horns tail gate anti-theft mod added a trailer hitch relocated 7 pin in bumper rear diff breather mod Magnaflow muffler kenwood KDC-X895 deck
    i was looking at my truck today and noticed it seems to lean slightly to the driver side and though maybe i was on un even ground so i pulled to a flat spot in my parking lot and it still seemed to do that same so i took at tape measure and measured the distance on all for tire to the fender so see if there is a difference and there was, the passager side distance was 1/2 an inch greater then the driver side:S?
    anyone know why this would be or is im just seeing things or do i have something broken in the truck
    thanks for the help
  2. Feb 17, 2011 at 4:32 PM
    RCBS
    RCBS How long you willing to tolerate this crap??
    Harden your bark, there are storms on the horizon.
    Goodbye 06, Hello 21. TRDORDCSBMT
    Tornado intake, Duralube, Fartcan.
    Search "taco lean".
  3. Feb 17, 2011 at 4:33 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
  4. Feb 17, 2011 at 4:34 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    you have taco lean. nothing much to worry about...most of our trucks lean to the drivers side slightly due to weak leaf springs.
  5. Feb 17, 2011 at 4:35 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Really? my XR's solid. but it also comes with different stock suspension
  6. Feb 17, 2011 at 4:36 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Try turning it around 180 degrees. It has to do with the curve of the earth and your location on it.:D
    Actually, let me guess. Your measurements look something like this:
  7. Feb 17, 2011 at 4:39 PM
    nb_tacoma
    nick
    Thunder Bay, ON
    yeah the measurements are like that (1.75).. thanks for the help guys..
    now is there anyway to adjust or fix this or just let it be?
  8. Feb 17, 2011 at 4:39 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Cmon be nice to the guy.. We were all new once.
    Here ya are bud.
  9. Feb 17, 2011 at 4:42 PM
    MTgirl
    Weesa
    No harm to the truck to leave it like that but if it bothers you...
    some people have used spacers/shims in the leaf pack. or do it the TW way and go all out on a new suspension. Most aftermarket suspensions account for the lean and correct it.
  10. Feb 17, 2011 at 6:06 PM
    RCBS
    Did not mean to be short. It was a quick answer between cod matches.
    NB, you don't have to do anything about it if you don't want to. The 4wd models are sometimes worse because of the transfer case weight. The toytec shim will level it out, but unless it really bothers you, save some $$ and forget you ever noticed. :)
