Is Something Wrong with my Setup? New Lift...Lot's of Pictures! Need Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Jun 27, 2010.
  1. Jun 27, 2010 at 10:53 AM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I put on the Toytec ultimate lift kit, TC UCAs, 17" Moto Metal 951s and 285/70/17 BFGoodrich KM2s. The front went from 34.5 inches (stock) to about 40.5" (after everything went on). I know the KM2s added about 1 inch of lift so this means the front coilovers lifted the front ~5", right??? The coilovers are preset to 2.5-3.0" of lift from Toytec so I'm not sure why I got so much more lift. I'm worried I did something wrong.
    I really like it and it all looks good but the last thing I want is something to fail. Please look at my pics and let me know if you see anything I may have done wrong. This was my 1st ever lift install so it wouldn't surprise me if I screwed something up.
    Front measurement before the lift...
    Front measurement after the lift...
    Rear measurement after the lift...the rear is a tad higher than the front which is great...
    Shot of the whole thing...
    Passenger side pic...
    Is the ball joint in a normal position? It looks like the extra high has the ball joint maxed out. Please look close and tell me if something is wrong. :D I don't want anything to fail :eek:
    Pics of the front coilovers and UCAs on both sides...
    Thanks for the help and if you see anything wrong please let me know...seems like I got too much height in the front but not sure since I didn't change the height of the preset coilovers.
  2. Jun 27, 2010 at 10:56 AM
    The End
    The End Support our troops!
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    2.5 King RR in front, LR ucs' s, 2.0 King RR rear, B.A.M.F shock mounts, ATO shackle flip, 4X sliders, ARB front bumper with XRC8, CBI hc rear, weathertechs, Leer cap, Thule rack, ubolt flip, etc.
    Are you taking in to account the larger tires as well. You should measure from the center of the hub to the fender to get an accurate measurement.
  3. Jun 27, 2010 at 10:58 AM
    Chad
    Chad Well-Known Member
    Chad
    Raleigh, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- BHLM -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- 09+ Access Cab Rear Headrest Removal
    I do agree that the balls look stressed, but what do I know lol. Just for future reference, you got the Ultimate lift didn't you? What "rear options" did you get?
  4. Jun 27, 2010 at 10:59 AM
    jmed99
    SC
    That is exactly where I measured...center of hub before and after. I got a total increase on the front of 6". The KM2s I think are 2" more in diameter so that lifts the truck 1". This results in a 6 -1=5" lift from the coilovers, right?
  5. Jun 27, 2010 at 11:00 AM
    jmed99
    SC
    I did the 1.5 TSB AAL.
  6. Jun 27, 2010 at 11:04 AM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    30" - 34.5" so 4.5" with the rugged trail pictures. From tire to wheel well.
    33" - 40.5" so 7.5" with the bfg pictures. From tire to wheel well.
    I know it's a rough estimate but that's about a 3" difference.
  7. Jun 27, 2010 at 11:04 AM
    06aztaco
    06aztaco Screw you guys, I'm going home.
    Cole
    Phx AZ
    06 Prerunner 2.7
    No matter what size tires you put on the center of the hub won't be any further or closer to the fender just because of the tires. It'll just fill out the space between.
  8. Jun 27, 2010 at 11:05 AM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    well, stock measurement from center front hub to fender is just about 20". do that measurement as it will take out other varables (ie tire height, etc). you should be just about 22.5-23" from my understanding of the 2.5'3" toytec lift.
    do this measurement and report back so we can help better.
  9. Jun 27, 2010 at 11:06 AM
    Chad
    Chad
    Raleigh, NC
    Had you done the TSB? So do you have 4 or 5 springs now?
  10. Jun 27, 2010 at 11:07 AM
    jmed99
    SC
    Oh...I was measuring from the ground to the fender at the center of the wheel.
  11. Jun 27, 2010 at 11:10 AM
    jmed99
    SC
    Right now from center of hub to fender is 25"
  12. Jun 27, 2010 at 11:10 AM
    jmed99
    SC
    5
  13. Jun 27, 2010 at 11:12 AM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    That's what I meant in my first post, you would have to have the before measurement to know total lift.
  14. Jun 27, 2010 at 11:14 AM
    jmed99
    SC
    Before lift...this is another measurement I took before the lift. Help this helps...
    Looks like the center of the hub is at about 18" from the ground. The height is 34.5 so 34.5-18=16.5 from center of hub to fender. now that same measurement is 25" so 25-16.5=8.5" That can't be right.... :(
  15. Jun 27, 2010 at 11:15 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    im at 25" w/ my 4" lift spindles and DRs at ~1" lift!! lower those COs so that your at 22.5-23" up front and you'll be good to go. im assuming you havent got an alignment yet, as there is no way they could have gotten you good numbers!
  16. Jun 27, 2010 at 11:16 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    stock is just about 20" front center hub to fender, we can roughly base his 25" from there...
  17. Jun 27, 2010 at 11:17 AM
    The End
    Tim
    Lakeland, Fl
    09 A/C 4wd M6
    I can't really tell where the center measures up. Just take that number and pretend it's the start of the tape measure and go from there.
  18. Jun 27, 2010 at 11:17 AM
    m0nster986
    m0nster986 ♥ Emergency Medicine
    SoCal
    When were they installed? Perhaps your setup needs time to settle.
  19. Jun 27, 2010 at 11:26 AM
    jmed99
    SC
    If I adjust the front down 2" then the rear will be 3" higher...I thought it was supposed to be level...what am I missing?
    I have gotten an alignment.
    Thanks for the help guys!
  20. Jun 27, 2010 at 11:32 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ well, the rear is like 2.5" higher stock...so you throw on 2.5" front lift and your level (this is the exact setup i ran before i redid my front end), then you add the AAL to the rear, you have your 2"+ of rake back...at least thats how my math comes out!
