Is stock better....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toyo freak, Dec 24, 2010.
  1. Dec 24, 2010 at 9:32 AM
    toyo freak
    toyo freak [OP] Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Alright so here is the deal. I have a stock 2010 4x4 with LSD. I want to lift it but my knowledge attained from this site is curving my decision. The truck stock is very capable, even with dunlops ( Wet Alabama clay was no match). Of course I like the look of the taller truck, but it seems lifting it decreases downtravel which is what helps you keep going when your truck leaves the ground or bottoms out. No we dont have much sand or hills just mud and more thick mud. And no I am not talking about body lifts or spacers. I want to debate is stock setup as capable as say OME or toytec ULK, maybe some even higher setups like icon.
  2. Dec 24, 2010 at 9:42 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    I am at the same fork in the road I really want to lift it but at the same time I dont.
    I was told we can rock 265/75/16's at stock, I think Im going to throw some on and see what if looks like then, I just want it a tad bit higher.
    If I still dont like it i'll end up lifting it.
  3. Dec 24, 2010 at 9:45 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    Better tires, specifically tires made for better off road performance, are going to provide your truck more off road capability (when compared to a truck with stock tires and lift.) Tires will be your best investment at this point because they will provide additional clearance (sometimes as much or more than the inexpensive lifts) and better traction.
  4. Dec 24, 2010 at 9:52 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Just so I know, with 265/75/16's wont rub correct?
    I know that will give me a little lift. Compared to stockers!
    Going with BFG A/T's
  5. Dec 24, 2010 at 9:53 AM
    jandrews
    '09 FourDubDee TRD OR
    If you lift it right, it'll preserve your downtravel and add suspension travel overall, but it's going to be expensive.
    You'll need extended travel coilovers from a top-tier manufacturer like Icon, King, or Fox. You will also need uniball UCAs with misalignment spacers (Total Chaos, Camburg, DSM, etc).
    To keep all of this from having the retarded baja ass sag, you'll want to bump the rear up as well, meaning you'll need at least some Bilstein 5100 shocks and an AAL.
    All of this is going to weigh in around $2000 to $2500 for parts. The install will be more if you don't do it yourself, but you really should do it yourself. It's really less of a lift and more replacing the entire suspension with a performance suspension.
    You won't be able to pull this off with an OME or Toytec kit.
    Correct. If you really want solid offroad traction, you should consider an MT. But be prepared to sacrifice mileage and have some road noise.
  6. Dec 24, 2010 at 9:55 AM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    BFG A/Ts should be no problem. MTs with large side lugs may touch at full lock, my Toyos very rarely rub.
  7. Dec 24, 2010 at 10:04 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Thanks, yeah I had MT's on my XJ they were beastly, off road and beastly on road :lol
    I'll be going with A/T's this is my DD
    Good stuff to know thanks
  8. Dec 24, 2010 at 10:13 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    I feel the same way. HMMMMMM????? I love my Sport Editions 4x4 abilities on road as well as off. I lucked out with a great freaking tire. Bridgestone Dueler Revo-265/70/17. On the road this really is an awesome truck! Handling is fantastic for a truck. Then I think about a slight lift and the looks as well as function for off-road. Then look at cost plus fuel mileage change. HMMMM?????? What do I do?
  9. Dec 24, 2010 at 10:21 AM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    think im gonna try duratracs and skid plates!
  10. Dec 24, 2010 at 11:07 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    very good start.then go from there cause once the mod bug gets you,its hard to kill him.lol.
  11. Dec 24, 2010 at 11:09 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Stock is only better for resale. And that's because you won's get back all the $$ you spent on mods. :D
  12. Dec 24, 2010 at 12:35 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Lift: front - 5100s set a .85 , rear - spring TSB
    Tires: 265/75R16 Duratracs on stock ( painted ) steel rims
    I have found this to be a perfect set up.
    I have may-be 1 inch of total lift, no rubbing or vibration issues
    but have had no problems getting around, and looking good!
    Haven't go stuck yet, love the Duratracs !!!!
  13. Dec 24, 2010 at 12:37 PM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    Wish they would do the TSB for mine, I can tell mine sags and they say no
    Eh I'll order the AAL
  14. Dec 24, 2010 at 12:38 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Sweet rig! My dad has duratracs and they have been great! They throw mud like you would not believe! Gonna be my next tire
  15. Dec 24, 2010 at 12:39 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Bump for math nerds who can calculate travel and tell me more about limited up and down travel....
  16. Dec 24, 2010 at 12:41 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    In case there is any question. i want to know do you think a stock setup with mud tires could keep up with a similar set of tires and an averaged priced 3" lift?
  17. Dec 24, 2010 at 12:44 PM
    skistoy
    Western New York
    Have always believed these trucks are so good except for the stock tires.
    the change is like night and day once they are replaced,
    and i dont need a big lift to get where im going.
    hell if it wasnt for the TSB , i probabaly wouldnt of got the 5100s
    But i have been so happy with this set up.
  18. Dec 24, 2010 at 2:35 PM
    Wile
    Wile Well-Known Member
    Tim
    New Mexico
    08 4x4 DC TRD Offroad
    Pioneer AVH-5600BHS, ScanGauge, Wet Okole Seat Covers, Allpro Aluminum front bumper, Allpro Aluminum IFS skid plate, Allpro APEX rocksliders, Warn 9500s winch
    I'm probably stating the obvious but here it goes. In general your truck will perform very similar to a truck with a 3" lift. In some cases you will perform better (where wheel down travel is needed for traction on berms and rocks). Where you will have trouble is when you need extra center ground clearance and higher approach and departure angles. Having skidplates will protect your truck in those instances. Just bring a good recovery trap and a friend with a truck.
  19. Dec 24, 2010 at 4:01 PM
    DevL
    DevL Well-Known Member
    No, due to clearances and the fact you have to run slightly smaller tires. Downtravel is over rated unless you remove your sway bar. Put in a 2.5" lift with 1" more travel. You lose 1.5" down travel and gain 2.5" up travel... it will be better overall and you can run a larger tire.
  20. Dec 25, 2010 at 7:12 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Yea but I cant afford expensive lifts- University of Alabama has all my money. :D
