Is synthetic oil in the REAR differential ok?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTakeover, Mar 17, 2015.
  1. Mar 17, 2015 at 8:27 AM
    TacoTakeover
    TacoTakeover [OP] Well-Known Member
    Or would y'all stick to regular for the rear? I read somewhere on here that some people avoid putting synthetic only in the rear for some reason. I was planning on doing mobil 1 synthetic 75w-90 in the front, TC, and rear but now I'm not sure about the rear. Thanks!
  2. Mar 17, 2015 at 8:31 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    I read that a while back as well. IRC, supposedly the synthetic oil can cause vibrations in the rear.
  3. Mar 17, 2015 at 8:34 AM
    TacoTakeover
    YES! Now that you've said that, that's exactly what I remember reading now!
  4. Mar 17, 2015 at 8:42 AM
    Bellis
    Bellis friggin rad
    Ben
    mass southshore
    pyrite 6-speed 2012 offroad
    driver mod
    x2 my 2012 is fine with synthetic in the rear, no mechanical LSD no problem
  5. Mar 17, 2015 at 8:52 AM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Running Amsoil 75w90 in my rear without any problems.
  6. Mar 17, 2015 at 8:53 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    x3 my 2011 had no problems with running synthetic in the rear. Check the rear diff and if you see a sticker that says to add the LSD stuff then you may want to pick up a tube.
  7. Mar 17, 2015 at 8:58 AM
    TacoTakeover
    Ahhh thanks for clearing that up! I have a 2013 Sport so I believe I have auto LSD and don't need the LS additive. So I should be ok with synthetic in the rear.
  8. Mar 17, 2015 at 9:27 AM
    TacoTakeover
    Yes thanks, Chris verified that for me yesterday. So will probably just use mobil 1 LS 75w-90 for all and if I can't find it I will then go with Amsoil or RP.
  9. Mar 17, 2015 at 9:32 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I had Castrol synth 75W90 in the rear diff before and occasionally got some chatter (non-LSD rear diff). The chatter is reduced after switching to Quaker State synth 75W140.
  10. Mar 17, 2015 at 12:40 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    I have run synthetic in the diffs for 383k miles without problem.
    Red Line 75W85 or Amsoil Severe Gear 75W90.
  11. Mar 17, 2015 at 12:44 PM
    Cmurder
    Cmurder 2011 TX TRD Offroad
    B.C.
    Kansas City
    2011 TX TRD Offroad
    nothing cool
    383k miles! Synthetic works and theres your answer.
  12. Mar 17, 2015 at 1:35 PM
    Therealwinshady
    Therealwinshady Well-Known Member
    Shannon
    Portland(west linn), Or
    2011 DCLB TRD Sport
    5100's and 885's, AAL, fog light mod, map light mod, viper 5706, OR tow hook, inverter anytime mod, Firestone air bags, devil horns, hood scoop riged light bar, 32 inch bumper light bar,
    nothing wrong with mine, 30k ago i switched.
  13. Mar 17, 2015 at 1:41 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    My manual calls for 75w90 I believe, and I have never seen 75w90 in non-synthetic (although I'm sure someone makes it somewhere) so I would say it works just fine.
  14. Mar 17, 2015 at 2:22 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Confirmed.
    I have an 07 with mechanical LSD. I have Mobile 1 75W-90 in the rear and have had to use 1 3/4bottles of XL3 (Ford) friction modifier to prevent the rumbles. :thumbsup:
