Is The 2015 Chevy Colorado In Danger Of Becoming A Failed Experiment?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Colorado S14, Feb 4, 2015.
Thread Status:
Not open for further replies.
  1. Mar 5, 2015 at 4:38 PM
    #401
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
  2. Mar 5, 2015 at 4:39 PM
    #402
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    It's a well known fact that you don't engage a rear drum parking brake in extremely cold weather. Sooner or later you'll get a freezeup. You had it in a F150 so you know it happens. Don't pretend like it only happens with F150's.
    Gen I Tundra actually was mid sized, look at the specs. Just barely larger than a Gen 2 Tacoma. Two inches wider on each side, not a BFD. Ten inches longer than a Gen 2 Tacoma, not a BFD since the bed was two inches longer and the rear step bumper was two inches longer. Approach/departure/breakover angles were roughly the same since the Gen I Tundra had an extra inch to 1.5" better stock ground clearance from front crossmember to pumpkin and the same wheelbase.
    Gen I Tundra didn't have the goofy crossover exhaust hanging low, no extreme angles on the driveline from transmission to pumpkin, smooth driveline. It was a beautiful blueprint for a Gen 3 Tacoma. They should have started from the Gen I Tundra platform for a new generation Tacoma instead of barely reforming a Gen 2 Tacoma.
  3. Mar 5, 2015 at 4:42 PM
    #403
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    If the leafs are like the last gen rado they are not worth a crap as well. Manufacturers make anything that's a 1500 or below with soft springs these days. Otherwise they get knocked for horrible ride etc... Gotta go 2500 to get a decent set of springs.
  4. Mar 5, 2015 at 5:00 PM
    #404
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB(sold)
    Lets say this. Same load on a taco vs the Colorado the drop on the Taco was a lot more.
    3 people on the end of the tailgate set the taco at the bumps. Colorado did not drop but 50% what the taco did and had more to go. Just could not get a 4th person on it. No room.
  5. Mar 5, 2015 at 5:36 PM
    #405
    monkeyface
    Colorado
    What would have been sweet for the Gen 3 is the Gen I Tundra Limited duplicated, but with the composite bed and rear discs.
    Lightweight smooth badass truck that's not too bulky. Gen I Tundra Access Cab I weighed at 4920 lbs curb weight, had to do so to get it titled in Colorado. With composite bed probably 4520 lbs.
  6. Mar 5, 2015 at 5:51 PM
    #406
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Both new trucks? Once you get the miles on those rado springs they will negative arch as well.
  7. Mar 5, 2015 at 6:34 PM
    #407
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Hmm Diesel powered camper ? Holy crap thats maybe best idea yet. Those old Toyota pickups where perfect small campers, chevy with 2200 lb payload could be turned into nice camper. Little lift and lockers front rear, plus nice plate bumper with winch and just got ultimate offroad camper.
    If that Diesel turns out to be good engine Tacoma will get clobbered.
  8. Mar 5, 2015 at 6:57 PM
    #408
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
  9. Mar 6, 2015 at 7:26 AM
    #409
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I never claimed this only happens to F150's, I just gave my personal experience. Jeez lol.
    I use my parking brake all the time on my sloped driveway. I can use pavement to unfreeze my rear brake if necessary in a jam, which I did on my old F150. That's cheaper than replacing a transmission because my driveway is on a 10 degree slope. 10 degrees on the parking latch over time will brake it at some point.
    The Tundra (Gen 1) was midsized by todays standards, but at it's time of release it was just slightly smaller than the half tons it had been designed to compete against. It had also been engineered to be a half ton, which the current Tacoma has not.
    As for the other design flaws you talked about, how about you wait to see what they did with the Gen 3 (detailed drive line examination at the dealership) rather than talk about something that there has been minimal information on other than "it's new".
  10. Mar 6, 2015 at 7:26 AM
    #410
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    It's not that much savings at first glance but it could be. I picture a parks department, like Seattle parks, ordering ~25 of these and they get shipped in straight to a truck body place. Work beds are sitting ready to be installed onto them. No removal of anything or modding. If you were the head of a parks department or something similar I bet this makes life a whole lot easier for you and will save tax-payer money. All those "difficult" hours of removing truck beds would be coming out of our pockets.
    And nobody wants those surplus base white and green beds or tail gates anyway. A local equipment auction sells piles of them per lot, they go for cheap prices and probably end up in the scrap metal heap.
    This is a good idea for a small truck.
  11. Mar 6, 2015 at 7:32 AM
    #411
    SwollenGoat
    SwollenGoat Onwards and Upwards!
    ‘21 ACLB, ‘99 XCLB, ‘92 RC, ‘85 4R
    Yep.
    They offered Cab Chassis with the out going Colorado for fleets, just a continuation of that.
  12. Mar 6, 2015 at 6:04 PM
    #412
    Mr.Gadget
    NC
    I wonder if the frame is different like they do on the HD Ram, Ford, and Chevy?
    They have a more flat or flat frame to let it have a lower center and more stable plus stronger.
    Im past the need to drive cool or up to date. I have thought about a flat bed with tool boxes or some type of set up that makes camping and hunting easy. Building a full size with a 10' flat bed and tool box set up would be killer. ATV and coolers would fit no trailer needed.
    A bed like the taco is too tight go use for an ATV need to use a trailer. If a little wider and taller it would work with a 6.5' bed maybe.
  13. Mar 6, 2015 at 6:56 PM
    #413
    SwollenGoat
    There are UTE beds for them.
  14. Mar 6, 2015 at 7:33 PM
    #414
    Mr.Gadget
    NC
    That is what im thinking but would need a ex cab or 4 door for the wife and dogs camping.
  15. Mar 6, 2015 at 7:39 PM
    #415
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    I can tell you this. My friend just bought one 2 weeks ago. It's already at the dealer. Went to start it and nothing. The ECM shorted out. They told him it was the 3rd one they have seen this year at that dealership.
  16. Mar 7, 2015 at 6:24 PM
    #416
    BlueT
    NorthEast
    There must be some kind of sale going on. IN last two days I had seen at least 10 of Colorado trucks.
  17. Mar 7, 2015 at 6:39 PM
    #417
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Saw a black canyon today next to me at the light. I will admit it looks sharp in person.
  18. Mar 8, 2015 at 9:09 AM
    #418
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Maybe that idiot running around talking about all the ECU failures coming got confused between the Colorado and the Tacoma. :)
    http://www.tacomaworld.com/forum/2n...-reach-biblical-proportions-coming-years.html
  19. Mar 8, 2015 at 6:18 PM
    #419
    nv529
    nv529 Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
  20. Mar 9, 2015 at 8:46 AM
    #420
    BlueT
    NorthEast
    You guys better watch out, mentioning frame rot or anything else related to Tacoma will get you banned...
    Remember.... Everything is Awesome.
    https://www.youtube.com/watch?v=9cQgQIMlwWw
Thread Status:
