Is the ScanGauge II Worth it?
Discussion in 'Performance and Tuning' started by Swimmerboy2112, Jul 29, 2012.
  1. Jul 29, 2012 at 10:50 AM
    Swimmerboy2112
    Swimmerboy2112 [OP] Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    Hey guys,
    I was thinking about picking up the ScanGauge II. As you all know, the gauges on 1st gen Tacomas are lacking. There are only 4 gauges, RPM, Speedo, Fuel, Engine Temp.
    I found there to be a few options that would come in handy on the ScanGauge. I like to be able to keep track of other things going on in the vehicle. So I guess my question here is, before I drop the $160 or so, is it really worth it to buy the ScanGauge II? Is there something better out there?
    -Brian
    *This thread is worthless without pics!
  2. Jul 29, 2012 at 11:02 AM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    Yes. Check eBay first that's we're I got mine. (120-130$) I used it to check codes and monitor my mpg. It's a cool little addition to have. Unfortunately mine was stolen. :(
  3. Jul 29, 2012 at 11:07 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    That sounds like a good deal. I know they have the package with the mount that goes above the rear view mirror for, I wanna say $170?? But I will check ebay first.
    It's a shame someone stole yours, some people.... I recently caught someone trying to steal my motorcycle.... But I digress.
  4. Jul 29, 2012 at 11:14 AM
    MiikeyD
    Upland, CA
    Try finding the SG first and then look for the mount separate on Amazon. Just checked eBay and wow prices have gone up.. Looks like you should bid on this one though. http://www.ebay.com/itm/ScanGuage-2..._Automotive_Tools&hash=item3f1a3b6713&vxp=mtr
  5. Jul 29, 2012 at 11:23 AM
    chewingonabone
    chewingonabone Well-Known Member
    Josh
    Charlotte, NC
    09 Tacoma SR5
    Retrax One tonneau, bull bar, step bar, PL8521
    Have you looked at the Ultragauge? Seems to do everything the scangauge 2 does at about half the price.
  6. Jul 29, 2012 at 11:29 AM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Thanks for the link, gonna keep my eye on it!
    No I haven't, i'm not even sure whats all out there, hence the reason for this thread. I'll check into the Ultragauge though thanks!
  7. Jul 29, 2012 at 11:41 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Ck out Garmin Ecoroute. It does the same thing but through ur phone or garmin gps.
  8. Jul 29, 2012 at 1:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    I have the UG, and am reasonably happy with it, but it has some serious drawbacks over the SG.
    First and foremost, if you mount it in any way where the cable is semi-permanent, you're stuck. The cable does not disconnect from the UG. Mine is mounted above my mirror and the cable routed under the headliner and down the A-Pillar.
    If I were parking at the airport for a week and wanted to remove it and leave it at home, I'd have to pull the pillar cover and remove the entire cable.
    Scangauge unplugs so you can take it with you every time you park. That's a BIG drawback on the UG because from the outside of the truck, it looks similar to a GPS.
    Buttons are on the back, so you can't flush surface mount it. It has to be elevated above the mounting surface enough to get your fat fingers behind it.
    Features....
    I'm not aware of the features/limitations of the two devices on 1st-Gen, but on 2nd Gen, trans temp and some other readings are not available on the UG, but are on the SG.
    Yes, the SG is 3x the price, but IMHO, it is a better unit and worth it.
    Some day, I might upgrade mine to an SG and move the UG to my wife's Rav4.
  9. Jul 29, 2012 at 2:31 PM
    Swimmerboy2112
    Brian
    Walnutport, PA
    I'd rather have the device rather than use my phone.
    That pretty much made up my mind right there. I want to be able to detach it, I want to mount it flush if need be and I want to make use of all the features.
    Case closed, I'm going with the ScanGauge.
  10. Jul 29, 2012 at 4:00 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I like the Scangauge. It is more adaptable to different vehicles. You can program in settings that don't come pre-loaded, in case your vehicle uses more sensors that only its ECU sees but are no gauges for. The Ultragauge cannot do that.
  11. Jul 29, 2012 at 4:19 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Anybody know if the SG will monitor speed??
    Looking for something to run while I get my gauges working (yeah whatever its only been like a year or so... :eek:)
  12. Jul 29, 2012 at 4:24 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Don't think the OBDII output refreshes fast enough for use as a primary speedo and tach for shifting etc.
    How does a SGII compare to bluetooth OBDII adapter + Torque app for Android?
  13. Jul 29, 2012 at 4:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    There are a lot of gauges the UG can access that are not on the dash.
    I routinely monitor the exact engine temp, and also the intake air temperature.
    Oil pressure is one that it can't do, but I believe there is no linear OP sensor. Trans temp is available, but UG doesn't read it.
    Now.. this is for 2nd Gen. I don't know what may be lacking in 1st Gen.
    2nd Gen, absolutely. Once you get the unit calibrated it can replace your speedo, odo, and fuel gauge.
    Of course, you'll need a GPS to calibrate any of these units.
  14. Jul 29, 2012 at 5:52 PM
    Swimmerboy2112
    Brian
    Walnutport, PA
    Good to know.
    I never liked the idea of using my phone as one of these devices. Seems way too much trouble. I'd rather just buy something that has a dedicated purpose.
    Ah good point, I forgot you were talking about a second gen. I wonder what is lacking with the first gens.
  15. Jul 29, 2012 at 8:24 PM
    rushr
    rushr Well-Known Member
    04 DC TRD 4X4
    OME 883 Coils, Dakar Leaf Packs/D6XL AAL, Nitrocharger Sport Shocks, ARB Bumper, Warn M8000 w/Synthetic Line, BAMF Sliders, Odyssey Battery, ProComp 7069 15x8, BFG KM2 33x10.5x15, Frame End Cap Mod, Hayden Transmission Cooler
    The detachable cable is nice for using in multiple vehicles
    The Scan Gauge does pretty much all the same in the 1st gen. I mostly use it for engine temp, voltage and trans temp.
    In my wifes Explorer it just gets used to read error codes lol
