Is there a consensus here on differential oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, May 2, 2018.
  1. May 2, 2018 at 9:36 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Ive heard that running 75w90 oil in a 05-08 sport rear diff makes them act funny since it is not a dino oil like 80w90. Any thoughts on this? LSD additive is added of course
  2. May 2, 2018 at 9:38 PM
    1bad2k
    1bad2k Well-Known Member
    Lone Star State
    2017 Tacoma TRD PRO
    Yep..
    Key-Rei likes this.
  3. May 2, 2018 at 9:44 PM
    badger
    badger Well-Known Member
    07 SR5
    Answer to the original question: No, there will never be any concensus on any lubrication related topic......never.
  4. May 3, 2018 at 1:46 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    That's the truth right there folks.
  5. May 3, 2018 at 1:47 AM
    Key-Rei
    Key
    Florida
    That's the good stuff.
    I run this in my motorcycle diffs too. It's better than the hyper hypoid stuff it calls for and half the price too.
    1bad2k[QUOTED] likes this.
  6. May 3, 2018 at 4:07 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Put the proper viscosity oil in with ls additive if needed. The rest is noise.
    Biscuits, Blockhead and Key-Rei like this.
  7. May 3, 2018 at 4:28 AM
    NBourque
    NBourque Well-Known Member
    Nick
    Maine
    ‘21 PRO
    The amsoil made a huge difference in my 6 speed. A lot smoother shifts even in extreme cold temps and no more third gear grind.
  8. May 3, 2018 at 4:46 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Just use the Walmart brand dino oil. Unless you are racing, towing at max, or doing crazy stuff with your truck, you are throwing money away -- and it might even perform worse. Use the weight specified and add friction modifier. It's a gear box, not an engine.
    TacomaMike37, BillsSR5 and 757yotas like this.
  9. May 3, 2018 at 4:53 AM
    taco woodeye
    taco woodeye Well-Known Member
    san jose CA
    2018 SR 4x2 Utility Delete Midnight Black Metallic.
    Royal Purple 75W90 w/ Synerlec.
    It's da kine.
  10. May 3, 2018 at 7:45 AM
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    This for the 6 speed..
  11. May 3, 2018 at 7:54 AM
    LJrubi
    LJrubi Well-Known Member
    Dan
    North West NJ
    2015 MGM TRD Sport DCSB
    I throw my vote in for amsoil severe gear.
  12. May 3, 2018 at 8:01 AM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    This is money, thanks!
    I used redline all the way around last time. Thinking i may try Amsoil in the front and rear diff's and stick to MT-90 in the tranny and transfer case. See if there's a difference.
  13. May 3, 2018 at 8:03 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I always wondered if in some cases dino oil is better served than synthetic
    757yotas[QUOTED] likes this.
  14. May 3, 2018 at 8:07 AM
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
    Yup nuff said
    MolonLabeTaco[QUOTED] likes this.
  15. May 3, 2018 at 8:43 AM
    #35
    badger
    07 SR5
    If you don't use your truck hard, it's not a big deal. If you use it for towing or hauling, synthetic reduces the heat build considerably. The Tacoma is more susceptible than the average truck because of the axle size.
  16. May 3, 2018 at 8:45 AM
    #36
    757yotas
    Virginia
    2007 TRD Sport
    Ive heard Synthetic will cause the LSD clutch packs to slip and all kinds of strange sounds? Any thought on this?
  17. May 3, 2018 at 8:49 AM
    #37
    badger
    07 SR5
    My 07 had clutch packs before I went to the ARB. I had no issues with the synthetic once the LSD additive was in. I did use Mobil One then too. I used GM additive, which funny enough was used by the local Ford dealership too. It chattered like hell without the additive, but ran great with it.
  18. May 3, 2018 at 8:51 AM
    #38
    757yotas
    Virginia
    2007 TRD Sport
    Do you remember how much additive you ran? If i can get syn in there and not chatter that would be awesome
  19. May 3, 2018 at 8:55 AM
    #39
    badger
    07 SR5
    It's a small bottle, and I used it all.
  20. May 3, 2018 at 9:17 AM
    #40
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    yes to reduce MPG
    Aerose91[QUOTED][OP] likes this.
