Is there a consensus here on differential oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, May 2, 2018.
  1. May 4, 2018 at 12:03 PM
    #61
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I think I used valvoline, not sure but no complaints
  2. May 4, 2018 at 12:04 PM
    #62
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    I know. I wasn't sure if said oil works well in the engine, if their gear oil would work well in the diff.s. I hear otherwise
  3. May 4, 2018 at 12:13 PM
    #63
    badger
    badger Well-Known Member
    07 SR5
    It's an interesting study, but it would have more weight if it were not paid for by Amsoil.
  4. May 14, 2018 at 7:48 AM
    #64
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Toyota manual transmissions love Redline MT90 so that's all I've used in mine for many years, and I use it in the transfer case as well. I use Valvoline synthetic 75W90 in the front and rear diffs because I can get it on sale locally (just picked some up for $8/quart at Pep Boys last week).
    O'DubhGhaill likes this.
  5. May 14, 2018 at 7:49 AM
    #65
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    I use Toyota gear oil in my diffs and transfer case.
  6. May 14, 2018 at 2:07 PM
    #66
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Just decided to swap my diffs and tcase over to supertech full syn 75w90. At 5.50$ a qrt you cant beat it and it works just as good as any other brand ive ever used
    BillsSR5 likes this.
  7. May 21, 2018 at 4:03 PM
    #67
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Do I need LSD additives in the 2015 sport rear diff?
  8. May 21, 2018 at 7:26 PM
    #68
    StevoNB
    StevoNB Well-Known Member
    NB, Canada
    2020 DCSB TRD Sport 6MT
    No. No mechanical LSD after 2008.
    Slashaar[QUOTED] likes this.
  9. May 21, 2018 at 7:32 PM
    #69
    Slashaar
    Josh
    Kansas City, MO
  10. May 21, 2018 at 7:38 PM
    #70
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
  11. May 22, 2018 at 5:36 AM
    #71
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    super tech is made by WPP or warren petroleum products who make also MAG1 and Coastal and other lubricants. Most Toyota dealerships and Parts dept. will use MAG1 gear oil instead of the Toyota branded stuff. for an every 30k OCI you really cant beat Super tech.
  12. Nov 4, 2024 at 5:24 PM
    #72
    badger
    07 SR5
    I know this thread is old, but I had a lot to say in it. Now I have some new information that some might find interesting. Last spring I finally pulled the gen 2 (8.0/8.4) axle out. It had 195,000 miles on it, and it was getting tired. I replaced it with a gen 3 8.75" rear axle out of a 2018. This axle is pretty much plug and play for anyone interested. The 8.75 is what Toyota should have put in the gen 2, but they didn't even make it standard in the gen 3. It's only available in some models. Anyway, the 8.75 is a beast. It's not just .75" larger in diameter. Everything about it is hugely stronger. The axle tube, the housing, the thickness of the gears, everything. It even takes a full qt more oil. The axle I got was out of a wrecked truck with less than 10,000 miles. I put new gears in it and an ARB air locker. I was surprised to see that the old gear set barely looked broken in. When I put in my new gears, I also installed a temp probe, just like I did in my Gen 2 axle to monitor the break in, etc. It took nearly 8,000 miles for the new gears to fully settle down! I did the break in with dino oil, then switched to Redline as before. The bigger axle is running 20 to 30 degrees cooler! That's because it is sized right and running under much less stress as a result. For anyone looking for a rear axle upgrade for heavy use, this is it.
    3JOH22A, Squirt and pwtacoma like this.
  13. Nov 5, 2024 at 4:45 AM
    #73
    TJTM
    TJTM Active Member
    2009 2.7 l, 4x4 access cab
    I am not sure there's a consensus here on anything, not that that's uncommon for a forum.:)
    ridefreak and Slashaar like this.
  14. Nov 5, 2024 at 2:38 PM
    #74
    Williston
    Williston Well-Known Member
    2014 Tacoma DC SB 4x4 V6 040 [SL] SR5 Trim [TO] V6 Tow Package [ED] Entune Audio Plus
    Stock (99.999%) OEM Bed Floor Mat, OEM Front Bed Rail Cargo Net and hooks, OEM Gentex Auto-Dim mirror w/Compass & Outside Temperature Display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter), OEM All-Weather Floor Mats (summer).
    A very well known Toyota expert on YouTube verified one time that Mobil makes and bottles the Toyota labeled oils for them including their engine-oil, differential and transfer case oil and Toyota WS automatic transmission fluid.
    I don't tow anymore so I used Mobil1 Synthetic 75w90 gear oil in all three units when I changed them, and had the dealer do the fluid change on the transmission with Toyota WS fluid which I believe is a fully-synthetic version of Mercon-V fluid.
    Slashaar and SH10151 like this.
  15. Nov 6, 2024 at 5:29 AM
    #75
    Slashaar
    Josh
    Kansas City, MO
    I'm at 180k on Mobil 1 Full Synthetic fluids all around. No issues thus far.
