is there a horn mod????
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Oct 21, 2014.
  1. Oct 21, 2014 at 1:21 PM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    just wondering if anyone replaced the moped meep meep horns we have with something that makes more noise?
    I want something that honks and not a wussyfied meep meep
    I realize there is no end to aftermarket horns out there but just wanted to know what you guys are doing and if there is a popular choice that fits without needing modded brackets
    not looking for train horns or musical horns just as basic loud horn like something you yank off an old full sized truck that's a straight forward plug in deal not needing relays, air pumps, or extra wiring
  2. Oct 21, 2014 at 1:23 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I got the Hella Super Tones. Loud as hell!! Might upgrade the the Cadillac horn kits you see on ebay.
  3. Oct 21, 2014 at 1:25 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Yea the 5 lugs have a wimpy horn. Maybe go to a junkyard and look for some off an older big car, shouldn't cost much and be easy to fit.
    I thinj the perunners and 4x4 trucks might have 2 horns that would bolt directly on to yours.
  4. Oct 21, 2014 at 1:36 PM
    Madjik_Man
    Colorado Front Range
    Simplest mod is to just put the 01-04 horn in place. Plug and play. All you have to do is find a place to mount the second horn behind the grille. Plenty of holes/options on our core support.
    http://www.tacomaworld.com/forum/1s...djik-mans-laugh-him-build-24.html#post8540785
  5. Oct 21, 2014 at 1:36 PM
    Madjik_Man
    It isn't just 5 lugs.
    My 4x4 V6 TRD had the "meep meep" horn. All 95-00 did. They changed it in 01-04.
  6. Oct 21, 2014 at 1:37 PM
    Idaholandho
    Idaholandho The other white meat
    3 Now - 2022 Trail Edition, 2015 TRD 4x4 and a 2006 SR5 4x4
    2015 Tacoma, Magnuson Supercharger, Bully Dog Flash and GT, Safari Snorkel, Toytec BOSS 2.5 Coil Over Front, Toytec BOSS Aluma 2.5 Rear, Toytec 10 Leaf Pack, Stainless Brake Lines, Icon UCA's, CBI Reverse Adj Shackle Mounts, CBI Ubolt Flip Kit, Timbren Bump Stops, CBI Bushmaster 2.0 Front Bumper w/ Warn M8000S Winch and SR2 Rigid Flood Lights, CBI Bushmaster 2.0 Rear Swingout Bumper, Rigid SR2 backup lights and Dual RotopaX / Fuel/First Aid Pack, CBI Rock Sliders, CBI Full Skids and CBI Rear Diff Armor, BAMF LCA Skids, FrontRunner Outfitters Slimline II Roof Rack w/ Rigid SR2 40" Combo Light Bar, Rock lights, Rigid pods in Bed Rack, Intelligent Battery System w/ Dual NorthStar batteries, Spod Power Distribution, illuminated switch panel in sunglasses holder, Viar Extreme Duty On-Board Air w/ 2.5 Gallon Tank under bed, Air 2 Air Sys, Magnaflow Exhaust, Fuel Off Road Trophy Wheels, 285/75/17 Toyo Open Country R/T, Diff breather mod, FX-R BHLM Demon Eye headlights, Esuse LED Fog Kit, Pelfreybilt Camera Relocation mount, Pelfreybilt ax/shovel bed mount, Debadged, tint, a 2006 Tacoma SR5 and a 2022 Trail Edition
    Train horn or gtfo
  7. Oct 21, 2014 at 2:19 PM
    keakar
    karl
    louisiana
  8. Oct 21, 2014 at 3:07 PM
    Indy
    Indy Master of all I survey.
    I love the taco horn. You have some a hole cut you off and run you into a ditch so you lay on the vehicle equivalent of 'HEY SAILOR! WHOOP WHOOP!'
  9. Oct 21, 2014 at 3:43 PM
    CantSitStill
    CantSitStill Well-Known Member
    FTR
    CNY
    I have both a twin and a triple tone Hella air setup if you want either. I used to call it the "green light wake up"
  10. Oct 21, 2014 at 3:48 PM
    keakar
    karl
    louisiana
    thanks but I don't want an air horn, I just want it to sound like a regular loud horn and not so much to scare people lol :p
  11. Oct 21, 2014 at 4:17 PM
    toyodajeff
    jeff
    06 reg cab sr5
    The old horns sound like a dodge road runner horn.
  12. Oct 21, 2014 at 4:30 PM
    keakar
    karl
    louisiana
    lol ok well that's out then :p
  13. Oct 22, 2014 at 3:20 AM
    CantSitStill
    FTR
    CNY
    New Taco horn isn't bad. Non air Hella is a nice sound. Just find a vehicle that you like the sound of and steal their horn.
  14. Oct 22, 2014 at 6:09 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    A local guy here put a set of 4 cadillac horns on his taco that he got out of a junkyard. Pretty loud, but low.
  15. Oct 22, 2014 at 6:41 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    I'm using the twin Hella horns off an old Land Rover or maybe it was a Mercedes. They are real loud and kinda deep.
  16. Oct 22, 2014 at 6:41 AM
    keakar
    karl
    louisiana
    thanks for all the help guys, think i'll try the wolo and see how long it lasts.
    I had one on my motorcycle and it was nice and loud but exposed to the elements like it was, the shell soon filled with air driven water so it crapped out after only a few weeks.
    I will still keep an eye out for a junker somewhere that I can get a free horn from, because the ones people sell want like $25 or more for em
    well I think maybe his mistake was trying to run them without a separate power supply and relay, if you put too many things on one wire the voltage drops way down. because I don't think Cadillac horns should have a low sound????
  17. Oct 22, 2014 at 10:17 AM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    I used a relay but thanks for the low voltage lesson, it has been awhile since 8th grade. ;) It is obvious you have never heard a Caddy with the four horn option. Four horns and each horn is a different note. It screams, " I am a retired, pretentious, over insured old prick so GTFO of my way! Haha
    Here is a popular link...
    http://www.yotatech.com/f2/replacing-4runner-horns-american-car-horns-210952/
  18. Oct 22, 2014 at 2:39 PM
    keakar
    karl
    louisiana
    lol, well my uncles caddy will scare the hell outta you and it only has 2 stock horns but they are loud buggers
  19. Oct 22, 2014 at 3:56 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    SshhheeeeTTT!!!
    That there must be the holy grail o' Dodge!!!
    Never heard of a Dodge Road Runner, must be super rare 1 of 1...
    I have heard of a Plymouth Road Runner and a Dodge Charger.
    Another one to be on the look out for is the Plymodge Road Charger GTX... That one sounds like a cricket fart...
    j/k
  20. Oct 22, 2014 at 4:03 PM
    2012tacolover
    2012tacolover Well-Known Member
    Norm
    CA/AL
    White PreRunner TRD Sport DCSB
    Tinted Windows, Black Nerf Bars, LED Dome & Map Lights, Snugtop Xtra-Vision, WeatherTech Digitalfit front and rear, trimmed Front Mud Flaps, BFG A/T KO's, Matt123 White Skid, Devil Horn Emblem Wet Okole front and rear seat covers! Future Stuff: Lift and new Wheels! :)
