Is there a sensor for being in Park to allow the key to be removed?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mac The Steve, Jan 13, 2017.
  1. Jan 13, 2017 at 3:49 PM
    Mac The Steve
    Mac The Steve [OP] Member
    Central CA
    Tacoma SR5 4x4
    Custom Innovation shell
    Hi all - my 1995 SR5 has been having a recent issue. Sometimes I park, turn off the truck (and put the it in Park) but cannot turn the key completely to the position that usually allows you to remove the key.
    (It isn't a key or a key ignition switch issue, however, I have a new factory key & have had the locksmith inspect the ignition switch. And not a wheel lock issue)
    My work-around is to start it up, drive an inch, park again & try it all over. If it still doesn't come out, I start up, back up, & try again. Sometimes this doesn't happen at all, & sometimes it takes me 10 times going back & forth. So I think there's a gizmo that senses when its in park. Any ideas?
  2. Jan 13, 2017 at 3:50 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    So far as I know the key can only be removed in Park.
  3. Jan 13, 2017 at 3:54 PM
    Mac The Steve
    Central CA
    Tacoma SR5 4x4
    Thanks DCSBFTMFW. Perhaps I wasn't clear. I've never wanted or tried to remove the key in any gear except Park. The key simply doesn't turn all the way off to be removed once I am in Park.
  4. Jan 13, 2017 at 3:56 PM
    T4RFTMFW
    10-4.
    I'd think it's an ignition cylinder thing, but I'm not terribly familiar with what communicates Park to the ECU and (assumedly) allows the cylinder to return to position and let the key be removed.
  5. Jan 13, 2017 at 5:36 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    I went thru the same crapola a few weeks back. There are some write ups on this.....
    https://www.tacomaworld.com/threads/key-stuck-in-ignition.44299/
    https://www.tacomaworld.com/threads...ease-without-backing-up.412153/#post-11804157
    https://www.tacomaworld.com/threads/gearcruncher-help-or-anyone-else-solved-for-now.460675/
    Mine was that the bushings that held the gearshift in place had worn down not letting the pin know about it being in park. The only way I was able to release the key was to disconnect the battery, and that opened another can of worms with the RS3200.
  6. Jan 13, 2017 at 6:20 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    yes there is a "sensor" so to speak. it's usually built into the neutral safety switch. if it's not sensing it's in park, it won't release your key. but also, if the actuator isn't properly turning or actuating, it may just be a bushing between the lever and the switch that is the issue.
  7. Jan 13, 2017 at 6:37 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Yeah, 1st thing I replaced when it started, wasn't it. $120 lesson.
