is there a specific order in which you replace spark plugs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by NotstockTRD, Oct 25, 2009.
  1. Oct 25, 2009 at 11:23 PM
    NotstockTRD
    NotstockTRD [OP] TRD
    st louis
    99 TRD Prerunner V6 with many mods..
    Shitloads
    on 3.4liter V6? thanks
  2. Oct 26, 2009 at 12:07 AM
    NotstockTRD
    st louis
    Shitloads
  3. Oct 26, 2009 at 4:51 AM
    machman
    machman Well-Known Member
    NE Alabama
    03 DC PreRunner TRD V6
    One at a time. :) I did mine recently. The ones on the driver side are a piece of cake. The pass side are just a little more trouble cause you have to remove the air inlet to access the middle plug/coil.
  4. Oct 26, 2009 at 6:23 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    there is no order just get them all done at once, good to see your replacing your plugs. let us know if it fixes your problem.
  5. Oct 26, 2009 at 6:26 PM
    Andyd103
    Andyd103 Well-Known Member
    Andrew
    New Hampshire
    2002 Tacoma SR5 4WD (3.4L V6)
    Suspension Lift, 40mm Turbo
    not really, i ussually do mine every 20,000 miles so i can easily remove them before i really need to remove them, i do it 1 by 1 take the wire off remove the plug replace the plug replace the wire and so on so you done mess up the order
