Is there a way to disable ABS?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Country101, Apr 27, 2012.
  1. Apr 27, 2012 at 6:43 AM
    Country101
    Country101 [OP] Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    My ABS have been a pain in my but and I dont know why they would ever be put on a 4x4. The first time I went down to the creek I tried to stop before I hit the water and slid in the silt for about 10-12 feet because they kept engaging. If they had locked up I would have stopped in 3. Then on the way home one day, I hit a reflector in the center line as I went to turn down my road and they engaged and almost made me go into the ditch. Toyota would not tell me how to disable them cause they are a "safety feature"(big sarcastic quotes there....). Does anybody know how to temporarily disable them(incase I sell it down the road, I want to be able to turn them back on)? I have seen a mod with a switch, I think, but I dont want to have a switch because they will never be turned back on while I am driving.
  2. Apr 27, 2012 at 6:47 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  3. Apr 27, 2012 at 6:54 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Pull ABS fuse and be done with it:D.
  4. Apr 27, 2012 at 7:05 AM
    Country101
    NW Arkansas
    Is there another mod that doesnt use a switch?
    How many fuses do I need to pull if I want to do that? Arent there 4-5 of them?
  5. Apr 27, 2012 at 7:37 AM
    Pugga
    Massachusetts
    Yeah, cut the wire and don't put the switch in...
    Make sure you use the correct write up, one is just for the Off Roads.
  6. Apr 27, 2012 at 10:47 AM
    Country101
    NW Arkansas
    I dont have to worry about any inspections. We dont have them here any more. Havent done it since I was a kid as best I can recall.
  7. Apr 27, 2012 at 10:49 AM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    Anthony250f wired up a switch to his and it works really good
