Is there an equivalent set up the Toytec bilstien coilovers
Discussion in 'Suspension' started by AllMountainToy, Jan 9, 2012.
  1. Jan 9, 2012 at 9:36 AM
    AllMountainToy
    AllMountainToy [OP] Well-Known Member
    Northern California
    2011 Tacoma Double Cab 4X4 TRDOR
    2 3/4 OME Suspension Lift with 885, with trim packer, 1/4" top plate spacer, swaybar relo bracket. Dakar leaf pack with 3rd leaf removed. 285/70/17" BFG AT. XD Wheels with 4.5 BS, Best Top Soft Top, Undercover winch mount with Warn 8k winch (with synthetic line), Pioneer touchscreen double din head unit. 4X innovations welded sliders. roof mounted DVD system.ATO dual battery tray with dual yellow tops. Rugged ridge isolator kit.
    TW, Is there a good equivalent to the Toytec Bilstein Coilovers in these areas:
    1. Spring rate (600lbs)
    2. Lift capability (up to 3")
    3. Cost ($799 assembled)
    Was about to hit the "purachase" button last Friday but thought I would ask and then go searching criagslist, this forum, ebay to try and find bit of a discount.
    Thanks
  2. Jan 9, 2012 at 9:38 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    well OME springs and shocks
    coils 170
    shocks 315
    cost = 485
  3. Jan 9, 2012 at 9:40 AM
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    OME 885 with 90000 strut = 2-1/2" w/no preload
    Shim to get 3" but your CV's (halfshaft angles) might be happier at 2-1/2"
  4. Jan 9, 2012 at 9:41 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Toytec offers TW a 5% discount I believe. You just missed their 10% discount they had running. I believe it ended yesterday.
  5. Jan 9, 2012 at 9:58 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Eibach's and 5100's.
  6. Jan 9, 2012 at 10:04 AM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    What do you mean by equivilent? Does it have to be adjustable, how important is spring rate?
    There are alternatives that might be cheaper but most of the ones listed so far will make you give up the adjustability.
  7. Jan 9, 2012 at 10:13 AM
    AllMountainToy
    Northern California
    Does not have to be adjustable. I want to avoid too much pre-load. I will be replacing the 2.25" top plate leveling spacer. With the 2.25" spacer and the rear TSB my front end sits almost 3/4 of an inch lower than the rear.
    Billies set at the top pre-load a ton and only give 2.5 I would still be approx 1/2" low in the front.
  8. Jan 9, 2012 at 10:22 AM
    AllMountainToy
    Northern California
    Thanks. I think the Eibach's are 620lbs. I may go this route.
    Thanks
  9. Jan 9, 2012 at 10:23 AM
    AllMountainToy
    Northern California
    Definitely agree. I will be removing the spacers completely.
  10. Jan 9, 2012 at 10:24 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Eibach's are on backorder.
  11. Jan 9, 2012 at 10:27 AM
    Pugga
    Massachusetts
    If it doesn't have to be adjustable, I'd seriously consider the OME set-up or one of the 5100/Eibach coils through Toytec. 5100's and Eibachs will put you at either 1.6" or 2.5" of lift of you can get their pre-assembled set up with a thicker top plate to get you to 3". The drawback to the Eibachs is what Ben mentioned, they're backordered...
  12. Jan 9, 2012 at 10:38 AM
    jflan
    Vancouver, WA
    This is pretty what ToyTec uses for their branded stuff, isn't it ?
    Couple of thoughts....
    The ToyTec "thread adjustable" C/O uses collar that locks onto a conventional shock. Before I bought into this I would go for a rebuildable C/O like Icon, King, SAW, Fox and maybe even the lower cost Radflow.
    That collar system doesn't turn me on.
    The OME system is always referred to as non-adjustable.
    Well, IMO it's not thread-adjustable but it is "shim adjustable."
    Good luck.
  13. Jan 9, 2012 at 10:46 AM
    AllMountainToy
    Northern California
    Thanks for all the suggestions everyone.
    So my last question before decision is made....(even with the eibach on back order).
    Other than the spring rate...what is going to be the main difference between the Toytec Bilstein coilover (red springs), and the Bistein/Eibach set at .85?
  14. Jan 9, 2012 at 10:48 AM
    08pretaco
    Oliver
    az
    easability of adjustability
  15. Jan 9, 2012 at 10:52 AM
    Pugga
    Massachusetts
    x2, that's why I asked if they had to be adjustable or not. You can't adjust the preload with a spanner wrench with the 5100/Eibach setup like you can with the Toytec/Bilstein setup.
  16. Jan 9, 2012 at 11:11 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    From my understanding, yes.
