Is this a good choice for a lift kit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chasegarrison4, Jan 6, 2015.
  1. Jan 7, 2015 at 1:30 PM
    #41
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    Went with Toytec :
    Front
    885 front coils
    Leveling spacers
    Diff Drop
    Rear
    Dakar Leaf packs
    Toytec Boss shocks
    265/70/17 BFG A/T KO
    Did not need UCAs....but had to remove the little mudflaps that are in front of the front tires because they rubbed. This is my 2nd truck with this setup, only differences on my '05 access cab had 883s and Bilstein 5100s on the rear.
    I like this set up because it is a moderate lift and we don't need a rope ladder to climb up in it....
  2. Jan 7, 2015 at 1:38 PM
    #42
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Don't need the diff drop either. Completely useless on a second gen Tacoma. Can cause more harm than good
  3. Jan 7, 2015 at 1:43 PM
    #43
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
  4. Jan 7, 2015 at 3:43 PM
    #44
    jhcole
    jhcole Well-Known Member
    Hunter
    Birmingham, AL
    '15 DCSB 4x4 TRD-OR MGM
    ToyTec 3" w/ Bilstein 5100's
    Can you elaborate a little more? I ordered the diff drop but would prefer to not install it and return it if it's not worth the trouble. I will not be exceeding 3.0" of lift. I didn't want to cause premature CV wear on my new truck.
    ALSO,
    I've been getting mixed feedback on the use of 5100s with the 2.5" ToyTec/Eibach coils PLUS the 1/2" ToyTec top-plate spacers (totaling 3.0").
    I've been warned 5100s shouldn't be used with 3.0" of lift, that they max out at about 2.75" and will be overstroked. I've been advised to ditch the 1/2" top plate spacers.
    Anyone have any experience with this?
  5. Jan 8, 2015 at 5:59 AM
    #45
    jhcole
    Hunter
    Birmingham, AL
    Kevin at ToyTec reassured my that there's no issue with running the 5100's with the 2.5" coil & 1/2" top plate spacer, that they install that set-up all the time.
    Still waiting to hear back on the necessity of the diff drop with that set-up.
  6. Jan 8, 2015 at 6:03 AM
    #46
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    If I could find the posts with the pics on here that showed the bad things with the diff drop I would post it. But putting them on our 2nd gens doesn't really help with any difference of angles on the cv's. Sometimes adding the diff drop puts it in harms way when wheeling. People have actually had bad damage from having it on there.
  7. Jan 8, 2015 at 6:22 AM
    #47
    Bjwilms7
    Bjwilms7 Well-Known Member
    Brandon
    Fairfax, VA
    09 Tacoma TRD Sport DCSB 4X4
    Billet grill, 20% tint, 265/70/17 BF Goodrich tires, 3" smittybilt nerfs, weathertech guards, Toytec 3" lift (Bilstein 5100s front/rear, Eibach, AAL), LR UCA's
    Getting the lift put on today with the stock shocks...Yes, it's going to suck for awhile, but I want to wait for the new bilsteins to come out.
  8. Jan 8, 2015 at 7:03 AM
    #48
    jhcole
    Hunter
    Birmingham, AL
    With the stock UCAs and no diff drop?
    Can't wait to see pics/measurements/alignment data
  9. Jan 8, 2015 at 7:08 AM
    #49
    Bjwilms7
    Brandon
    Fairfax, VA
    Yep! We will see.
  10. Jan 8, 2015 at 11:38 AM
    #50
    Bjwilms7
    Brandon
    Fairfax, VA
    Got to the shop and they said they'd need the truck for longer then I intended. Ended up rescheduling and purchasing the bilstein 5100s for all 4's from the same website. Been reading threads all day and figured I better do it right the first time. Thanks!
  11. Jan 8, 2015 at 5:16 PM
    #51
    jhcole
    Hunter
    Birmingham, AL
    So looks like I'll be the only one with this kit!
  12. Jan 8, 2015 at 5:43 PM
    #52
    Bjwilms7
    Brandon
    Fairfax, VA
    Sounds like we have the same set up. You have the toytec kit/bilstein 5100s right?
  13. Jan 8, 2015 at 6:09 PM
    #53
    jhcole
    Hunter
    Birmingham, AL
    Sorry I think I misunderstood. Thought you meant you were doing only 5100s instead of ToyTec kit.
  14. Jan 8, 2015 at 7:54 PM
    #54
    Captainskidmark
    Northern Illinois
    oops, forgot to mention my previous Taco I did buy but did not not install the diff drop kit....had 120k miles with the lift and no issues besides replacing cv boots after 110k miles.....both lifts i ran the stock front shocks.....
  15. Jan 9, 2015 at 4:41 AM
    #55
    Bjwilms7
    Brandon
    Fairfax, VA
    So they did say it was alright to put the 1/2 spacer on the bilsteins?
  16. Jan 9, 2015 at 9:27 AM
    #56
    jhcole
    Hunter
    Birmingham, AL
    Yes. Kevin at ToyTec confirmed they run this setup often. Talking it out made sense and I should have thought about it first, but the top-plate spacer goes between the strut assembly and the upper strut mount, therefore its not adding any length to the strut assembly, just moving the assembly down 1/2". The coils provide 2.5" of lift through their length and stiffness, so that's all the 5100 actually sees.
    My lift will consist of...
    Front: 2.5" 521600 ToyTec/Eibach Coil, 1/2" top-plate spacer, C477 Bilstein 5100 set to 0.0"
    Rear: 2.0" ToyTec/Deaver AAL, OEM TRD Bilstein HD shocks
    Jury is still out on diff drop, maybe a gametime decision.
    Can anyone confirm the real world measurements of front end lift they got with this setup (2.5" coil + 1/2" top plate spacer)?
    It's going on a DCSB, 4x4, A/T, so I know its one of the heavier weight configurations of the Tacomas.
  17. Jan 9, 2015 at 9:41 AM
    #57
    Bjwilms7
    Brandon
    Fairfax, VA
    Ok, great! Thanks
  18. Jan 10, 2015 at 8:03 AM
    #58
    jhcole
    Hunter
    Birmingham, AL
    Indecision wins again.
    I'm thinking of leaving out the top-plate spacer. Not only will this simplify the install significantly, I think it'll be better for the alignment.
    Since I really want to avoid aftermarket UCA's, I think I'm just going to install the 521600 coil with the 5100's set at 0.0". Hopefully this way I'm still within reach of decent caster numbers to maintain a straight tracking ride. Still curious to see what the rake will be with this set-up (ToyTec/Deaver ' 2.0" ' AAL in the rear).
  19. Jan 11, 2015 at 1:36 PM
    #59
    jhcole
    Hunter
    Birmingham, AL
    How much front lift did you get from the 885 coils and spacers (also what type spacers?).
    You said you got a decent alignment, do you know the caster numbers you achieved?
    Everyone has me worried now that after I put this lift on my truck will be floating from lane to lane all over the highway and the driveline vibrations are going to rattle the bumpers off.
  20. Jan 13, 2015 at 4:35 PM
    #60
    jhcole
    Hunter
    Birmingham, AL
    When's your lift going on?
