Is this a good setup?
Discussion in 'Suspension' started by Mattw, Aug 7, 2010.
  1. Aug 7, 2010 at 12:23 AM
    Mattw
    Mattw [OP] Member
    Az
    2010 BSP 4x4
    Tint, Hose Clamp Mod, Mud Flaps Gone, Foglights Anytime Mod, DTRL Mod, Grillcraft BG Grille... Then soon a 3" lift with 285/70/17 and 17" black wheels
    So i wanna get the Toytec Ultimate Lift Kit and put some 285/70/17
    ive heard you would rub but you could trim, then i heard even if did trim it wouldnt be that good to off road with this set up. So what should i do?
    Just get smaller tires, or would i be fine?
    Thanks
  2. Aug 7, 2010 at 12:26 AM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    wheel spacers
  3. Aug 7, 2010 at 12:28 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    You might rub less with different than stock wheels, maybe like 4.5" BS wheels. You will have to run it at the 3" then you might need to go with some aftermarket UCA which is another 500 bones on top of the lift and tires and maybe wheels and cab mount chop. But it all depends on how much and what kind of wheeling you do. If you are going crazy and just some light trails and such you should be fine wheeling with this setup but the downtravel is clsoe to nothing so the drive is going to be more harsh than stock but ebveryones does it and everyone loves it lol
  4. Aug 7, 2010 at 12:40 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    just go with 265's. cheaper, keep more horsepower, better mpg, problem solved ;)
  5. Aug 7, 2010 at 3:10 PM
    Mattw
    Mattw [OP] Member
    Az
    2010 BSP 4x4
    even with aftermarket wheels, i would still need to do a cab mount chop?
  6. Aug 7, 2010 at 3:28 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    No not for 285s, unless you ramp it off cliffs. Just some minor plastic trimming
  7. Aug 7, 2010 at 4:16 PM
    Mattw
    Mattw [OP] Member
    Az
    2010 BSP 4x4
    Ok thank you, thats what i wanted to hear!
  8. Aug 7, 2010 at 5:54 PM
    08pretaco
    az
    Ya sorry for not making that very clear lol
  9. Aug 7, 2010 at 9:27 PM
    Mattw
    Mattw [OP] Member
    Az
    2010 BSP 4x4
    I think i found a good set up, let me know if this sounds good to you guys :thumbsup:
    Lift- Toytec Ultimate Lift kit
    UCAs- Total Chaos
    Tires- BFG A/T 285/70/17
    Wheels- 17x9 4.5 backspacing
    Sound good?
  10. Aug 8, 2010 at 1:14 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    you'll still rub the frame at full lock, but lots of people run that setup and like it.
  11. Aug 8, 2010 at 12:39 PM
    Mattw
    Mattw [OP] Member
    Az
    2010 BSP 4x4
    ok i hope i dont have to many problems with that setup
  12. Aug 8, 2010 at 6:59 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    You should be fine. I dont run that setup but many people do. You may have to trim a little but not much. You should worry more about vibrations than rubbing.
  13. Aug 8, 2010 at 8:52 PM
    Mattw
    Mattw [OP] Member
    Az
    2010 BSP 4x4
    Is there a way to stop them, what are they caused from?
  14. Aug 8, 2010 at 9:00 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    I rub my body mounts with 285s at full lock and a bump
