Is this all I need to get both wheels in the back turning!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jdmjerry, Feb 9, 2011.
  1. Feb 9, 2011 at 1:59 PM
    jdmjerry
    jdmjerry [OP] Well-Known Member
  2. Feb 9, 2011 at 2:07 PM
    08bluetacoma
    08bluetacoma Well-Known Member
    Dave
    Ontario, Canada
    07 SR5 Rad Red
    6 inch fabtech alpine stereo flowmaster exhaust
    im pretty sure detriot lockers are locked all the time?? correct me if im wrong... another option is an arb air locker or a limited slip diff
  3. Feb 9, 2011 at 3:03 PM
    chris4x4
    chris4x4 With sufficient thrust, pigs fly just fine.
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    OP, If your looking for an LS Diff, look for the Detroit Tru Trac.
  4. Feb 9, 2011 at 3:12 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Probably need to give us more info on how you use your truck in order to get good info.
    Also, does the linked auto locker even come in a size for Toyota axles???
  5. Feb 9, 2011 at 3:13 PM
    cc350
    cc350 Retired Member
  6. Feb 9, 2011 at 3:18 PM
    jdmjerry
    whatever i need to get both wheels power so i dont get stuck with one wheel in the air spinning and the other on the ground not moving, thats what i want lol
  7. Feb 9, 2011 at 3:20 PM
    jdmjerry
  8. Feb 9, 2011 at 3:20 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    ARB Air locker.
  9. Feb 9, 2011 at 3:23 PM
    jdmjerry
    what about the link that the gentleman above just posted? that will not work
  10. Feb 9, 2011 at 3:24 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Agreed. Having seen one in action, I was impressed.
  11. Feb 9, 2011 at 3:26 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The "lunchbox" locker linked above will work and is less expensive, but has a few "interesting" characteristics on the street you should google up and be comfortable with before plunking down your hard earned denero
  12. Feb 9, 2011 at 3:29 PM
    jdmjerry
    haha thats all you had to say..
    well what about this detroit tru trac for toyota 8in 4 cycl which is what i have correct?
    http://nationaldrivetrain.com/shopsite_sc/store/html/d_truetrac_toyota.html
  13. Feb 9, 2011 at 3:37 PM
    jdmjerry
    didnt see any bad reviews for the "lunchbox locker"?
  14. Feb 9, 2011 at 3:40 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Well, I'd prefer you'd read comments from folks who've driven with it, than comments I'd give you second hand.
    I have an ARB, so I can say it's smooth on road and works well as I expect in locking situations off road. But it's expensive.
    Auto lockers and lunchbox lockers are fairly streetable, but they have been known to lock up on the street, when you don't want them to - especially in snow and ice conditions. Lunchbox lockers are the most affordable, since in addition to being less expensive they don't need a carrier replacement and re-shimming of the gear pack, so it's an install you can do yourself, or at least a less expensive install.
    Limited slip differentials are often driven on the street, and are considered by some to have better snow/ice performance than open differentials. (opinions vary) but they don't lock up tight in offroad "lifted wheel" situations, though they will force some torque to the driven wheel, especially if you add a touch of parking brake.
    Hope this helps, but you do yourself a disservice if you don't spend a weekend doing additional research in addition to what we tell you here in this forum.
  15. Feb 9, 2011 at 3:42 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Here's one, I found by googling the following phrase (including quotes as given)
    "lunchbox locker" driving characteristics
    http://www.offroaders.com/tech/Lunchbox-lockers.htm
    I don't mean to say they're awful and no one should ever use one. I mean to say it's different than a stock vehicle and you need to be aware of what it'll do.
  16. Feb 9, 2011 at 3:45 PM
    jdmjerry
    ok cool i just needed direction to research thanks for the help
