Is this amp any good?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cutter_, Dec 4, 2019.
  1. Dec 4, 2019 at 2:15 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
  2. Dec 4, 2019 at 2:44 PM
    Taco1.1
    Taco1.1 Well-Known Member
    2018 TRD Off-Road
    Debadged, Kenwood 9905 Head Unit, Tinted Windows, Remote Start
    Does it go up to 11?
    xxmagpulxx likes this.
  3. Dec 4, 2019 at 2:47 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    It’s listed as 4 channels. How are you powering the SW?
  4. Dec 4, 2019 at 2:48 PM
    Cutter_
    I was going to add one later on
  5. Dec 4, 2019 at 2:49 PM
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    It only has 4 output channels, so you could run the mids/tweeters, but not the sub. Assuming tweeters you are talking about are connected to a crossover that is also going to 2 of the mids. If you really have 2 separate tweeter channels, than you could only run the mids.
  6. Dec 4, 2019 at 2:50 PM
    rnish
    Tacoma 2nd gen
    So yes it can power 4 channels at a moderate levels (Good enough for most people). The +1 is TBD.
    xxTacocaTxx likes this.
  7. Dec 4, 2019 at 2:51 PM
    Cutter_
    so if I wanted to run a subwoofer, this amp is out of the picture? I would need a 5 channel?
  8. Dec 4, 2019 at 2:53 PM
    su.b.rat
    su.b.rat broken truck
    yes, but really if you want decent bass you'll need a second single channel amp for it. a five channel amp will underperform especially on the sub. unless you've got seriously cheesy drivers.
    12TRDTacoma likes this.
  9. Dec 4, 2019 at 5:41 PM
    AZF1504x4
    AZF1504x4 Well-Known Member
    It’s overpriced as well.
  10. Dec 4, 2019 at 5:55 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ideally if you want to run a subwoofer, you should always run an independent standalone amp to run a sub to get the best quality out of your sub.
    A 4 channel can still run all your speakers and your sub.
    If you run 2 channels for all of your speakers and tweeters as long as each channel can handle the RMS wattage capability the speakers are capable of putting out on each side then you can use both rear channels to power the sub. You can also run the rear mids and the sub together in the rear channel if you want to go that route as well.
    It's how I ran mine for a long time, but I noticed an IMMEDIATE DRASTIC change in clarity and quality when you run a dedicated amp for the sub, the speakers will get notably louder as well.
    Cutter_[OP] likes this.
